2004 coupe
Old May 21, 2008 | 09:01 AM
tnd's Avatar
tnd
Default 2004 coupe
has anyone had this happen to them?
when I come to a stop the engine sometimes seems to want to die but recovers and acceleration is sluggish
does not happen all the time
thank you
Tom
Old May 21, 2008 | 09:06 AM
spensley's Avatar
Default Re: 2004 coupe
Do you have any mod's?
Old May 21, 2008 | 09:16 AM
Yes. My wife was running regular fuel. Once she ran a few tanks of 93 octane the problem went away.
Old May 21, 2008 | 09:26 AM
tnd's Avatar
tnd
thank you for the reply, no mods and use 91 octane
Old May 21, 2008 | 11:52 AM
spensley's Avatar
Have you checked the obvious - clean air filter, plugs & gaps, plug leads etc?
Old May 21, 2008 | 01:56 PM
tnd's Avatar
tnd
Just had the oil changed about a week ago, I am not much of a mechanic, I did top off the gas yesterday maybe I got some bad gas (Shell)
Old May 21, 2008 | 02:31 PM
Oil shouldn't have anything to do with it. Shell should be good gas. Check your air filter.
Old May 21, 2008 | 04:35 PM
tnd's Avatar
tnd
My 2004 only has 16,000 miles on her, do you think the air filter could be the problem
Old May 21, 2008 | 04:38 PM
It depends on your driving conditions. If live in an area with lots of dust or junk in the air, it could.
Old May 30, 2008 | 07:42 AM
tnd's Avatar
tnd
thank you
Tom
Just an update, took the car to the dealer for the above problem, could not duplicate the concern but did do a scan and all that came up was code #P1600 which indicated "rough road detected" and something about a transmission hose, the "rough road detected" according to the service manager has been seen before but had no idea what it meant and was not in the code book, so maybe I did get some bad gas from Shell, will try Diamond Shamrock for awhile and see what happens
Old May 30, 2008 | 12:55 PM
spensley's Avatar
I always take what these people say about the codes with a pinch of salt unless I actually see the code my self. The last vehicle I had threw a code at one point, the CEL never came on, but the code said I had reached the maximum speed of the vehicle. I had not done that.
Old Nov 3, 2008 | 02:04 PM
tnd's Avatar
tnd
Just an update, opened the hood to check the oil and found that the engine cover and one large air hose (the ones on each side of the engine cover) was not installed properly after my last oil change, this is when my problem seems to have started, the engine cover was sitting at an angle and quite loose
could this have been my problem
PNA
Nov 12, 2020 04:44 PM
Soma
Dec 14, 2015 07:52 PM
Snake Eyes
Sep 28, 2015 08:55 PM
XWynd
Aug 11, 2015 03:45 PM
itsky
Aug 9, 2015 07:39 PM
