Check engine light came on.
Old May 24, 2008 | 01:50 PM
crossfirefrank's Avatar
Default Check engine light came on.
It's finally a nice day and decided to go for a cruise in the roadster and about a mile down the road my check engine light popped on. I went to autozone and he checked the codes and the code was PO453. The kid had no ideal what the code meant. I had him clear the codes and I'll see if it comes back on. Does anyone know what his code is and if you think it might be a hiccup in the system or have a problem.
Old May 24, 2008 | 02:01 PM
Default Re: Check engine light came on.
Did you buy one of the Needs Wings CAI?
Old May 24, 2008 | 02:04 PM
Yes-but it has not been shipped to me yet. I'd like to get this cleared up before installing it. The cars still in warranty and I'm sure they give me a hard time about his CAI
Old May 24, 2008 | 02:06 PM
Yep, take it in first, unless it has to do with the gas cap error code.
Old May 24, 2008 | 02:10 PM
robby363's Avatar
P0453- FUEL TANK PRESSURE SENSOR CIRCUIT HIGH.
Old May 24, 2008 | 02:13 PM
so what does that mean? to much pressure in the gas tank.
Old May 24, 2008 | 02:15 PM
Just remove and twist the gas cap on again. It could be as simple as the cap not on right, or it's the car has been sitting all winter. There's a good chance you will not see the error again.
Old May 24, 2008 | 02:29 PM
robby363's Avatar
I'd do what FP said to do and see if it comes on again. You can find info on the codes here.http://homepage.mac.com/gregmeach/XF...r_9-Engine.pdf
Old May 24, 2008 | 03:01 PM
Maybe you got mice in the gas tank LOL
Old May 24, 2008 | 04:19 PM
Moparrbust's Avatar
Hopefully you don't have a clogged fuel filter..............you're not gonna want to see the bill to have that sucker replaced. I just replaced mine this past week(necessary when you convert to E85 fuel) and the filter was $176+ tax(and labor if you can't do it yourself) retail..............luckily I got it for "only" $95 which is dealer cost no tax.
Old May 24, 2008 | 04:51 PM
I'll check the gas cap and keep you posted. I would hope it's not the filter only has 4k on it. sat in the garage a month without running maybe some pressure built up.
Old May 24, 2008 | 04:55 PM
Iamfink2's Avatar
I agree with FP I would remove gas cap and put it back on. My trouble code chart shows PO453 as "Evaporative Emission Control System Pressure Sensor High Input". By the way HDDP posted awhile back all the trouble codes for the Crossfire.
Old May 24, 2008 | 04:58 PM
Oh yeah, code PO453 also says it can also be car sitting in garage too long with only 4K miles. Needs more use .
Old May 24, 2008 | 06:57 PM
Moparrbust's Avatar
Gas isn't like wine............it doesn't get better with age. Unless you put fuel stabilizer in your tank while it rots away in the garage the fuel will break down and eventually get sucked up and into the filter.
Old May 24, 2008 | 08:09 PM
Codes with that problem were PO171 and PO174
Lean mixture / MAF sensor.
Old May 25, 2008 | 05:37 AM
Come on guys give me some credit I put 1400 miles on it this spring on the dragon run. Fp I'm thinking about the July trip to P.A. just have to figure out how I can explain my way out of being out of town on my birthday plus that trip should be good for another 1k on the clock.
Old May 25, 2008 | 07:12 AM
Frank, you should know I'm just razzing you.
Old May 26, 2008 | 05:12 AM
FP- I know you are. Update took the car out yesterday and the light came on before I got out of the driveway. Guess it goes to the dealer next week. Man thats a scary thought.
Old May 26, 2008 | 05:18 AM
Frank, you might want to try this first.
https://www.crossfireforum.org/forum...090#post243090
Old May 29, 2008 | 08:21 AM
Took car into local dodge dealer yesterday and had to leave it overnight. Dealer was really good and left the car inside overnight so nothing could happen to it. Picked it up today and they replaced the fog lights (got parts overnight) and had to order the siren. They found the problem with the check engine light on (code PO453) to be a corroded connection on the fuel tank. They cleaned and lubed the connector. Was very pleased with the service and gave me a new vehicle to drive overnight. When I get the new siren installed I'll let you know if the car chirps. I supplied them with the new part number for the siren which members state chirps.
