Check engine light came on.
Old May 29, 2008 | 08:26 AM
Default Re: Check engine light came on.
Frank,
Glad they took good care of your car and you.
It's nice to read a story with a happy ending.
Old May 29, 2008 | 08:35 AM
crossfirefrank's Avatar
I spoke with the mechanic and he told me he even put it up in the air overnight so know one could get in it.
Old May 29, 2008 | 08:46 AM
liberty1's Avatar
Frank you are welcome at our place anytime. Lots of room. Debbie would be more than happy to put a few miles on it for you
Old May 29, 2008 | 07:47 PM
Iamfink2's Avatar
Originally Posted by crossfirefrank
Took car into local dodge dealer yesterday and had to leave it overnight. Dealer was really good and left the car inside overnight so nothing could happen to it. Picked it up today and they replaced the fog lights (got parts overnight) and had to order the siren. They found the problem with the check engine light on (code PO453) to be a corroded connection on the fuel tank. They cleaned and lubed the connector. Was very pleased with the service and gave me a new vehicle to drive overnight. When I get the new siren installed I'll let you know if the car chirps. I supplied them with the new part number for the siren which members state chirps.
I put the new one on my xfire and it chirps once for unlock and three for lock and when you lock it and you have a door ajar (even the hood) it will only chirp twice to let you know.
Old Jun 1, 2008 | 05:31 AM
Bad news, met Gary & Ann (Rapp's Yellow CF) for dinner Saturday in Ann Arbor, about a 40 minute drive and on the way up no check engine light. Got back in the car to head home and as soon as we started it bang the light popped back on. I guess it's off to the dealer again.
Old Jun 4, 2008 | 07:31 AM
Just got back from taking my car in to dealership and the tech still seems to think the light comes on due to the corrosion at the connector/terminal at the gas tank. He is going to replace both the high pressure sensor terminal/sensor and the connector. He went to check availability of both and the Chrysler parts computer stated that neither item were available. He said they will have to contact Chrysler to see when they will be available. He also stated the sensor connector was only available as part of a large harness but would cut and splice it to the current harness if not he would have to disassemble most of the rear portion of the car to install the new harness. I'm starting to get a little worried about this since he is not even sure if this would fix the problem. He did call Chrysler tech support and they advised him to start with this since he could visible see the corrosion. I'll keep you updated as it progresses.
Old Jun 4, 2008 | 12:34 PM
Originally Posted by FP
Frank, you might want to try this first.
https://www.crossfireforum.org/forum...090#post243090
Have you tried this?
Old Jun 4, 2008 | 03:34 PM
yep, didn't work.
Old Jun 10, 2008 | 06:49 AM
Dealership installed the new high pressure sensor / fuel gage assembly today and hopefully this will fix my check engine light problem. The tech told me the dealership had to purchase a special tool from Chrysler to remove it. I did a search on the forum and it seems a few members have had to get the assembly replaced for the same reason.
2004_
Jul 9, 2025 12:39 AM
Hoppy
Dec 7, 2018 07:36 AM
jgreen
106
Sep 18, 2017 11:46 PM
spoiler
Sep 2, 2015 08:56 PM
axnguyen
Jul 21, 2015 11:41 AM
