how to remove alternator pulley.. ?
Old Jun 7, 2008 | 09:06 PM
HyprLtH20's Avatar
www.CustomCrossfire.com
Default how to remove alternator pulley.. ?
i need to remove my alternator pulley so that i can replace it with a larger one.. i have tryed everything i can think of to free it.. no luck so far. if anyone can help me out id really appreciate it! thanks in advance..
Old Jun 9, 2008 | 05:01 AM
spensley's Avatar
Default Re: how to remove alternator pulley.. ?
Big hammer to tap it?
Pulley puller - I know one of the other pulleys requires it, but maybe this needs a little hand.
Contact the supplier.
Old Jun 9, 2008 | 07:42 AM
HyprLtH20's Avatar
i think i have found the answer.. im going to try an aluminum strap wrench.. i just needed something to hold the pulley still while i got it loose. so we will see how it works out.. ill post here when i find the solution.
Old Jun 9, 2008 | 01:27 PM
HyprLtH20's Avatar
does anyone know which way the bolt on the pully is threaded? i cant tell if it is normal or if it is reversed.
Old Jun 9, 2008 | 01:33 PM
TVT_DESIGN
Guest
Posts: n/a
The nut is normal thread.
Old Jun 9, 2008 | 01:37 PM
HyprLtH20's Avatar
i appreciate it!
Old Jul 16, 2012 | 11:08 AM
Teck-9's Avatar
I'm having the same issue. Were you successful?
Old Jul 16, 2012 | 12:14 PM
Four year old post. He last posted in December 2010.
Old Jul 16, 2012 | 12:24 PM
FUBU's Avatar
also his webpage is for sale
Old Jul 16, 2012 | 03:47 PM
turbomar's Avatar
Use an impact gun to remove the nut while holding the pulley with a glove. Get a buddy to suspend the alternator by the pulley while you use a brass drift to tap the shaft out or use a puller if you have one
Old Jul 19, 2012 | 08:51 PM
Web 3.0's Avatar
Default
I use a chain grip to remove pulleys. I think I bought it at lowes. It is a set of vise grips with a short chain. You wrap the chain around the pulley, set the tension with the set screw as per normal vise grips and done. Wrap the pulley with a shop rag to prevent scratching it up.
syfi
Mar 28, 2026 04:14 PM
TerryR
Dec 13, 2019 03:27 PM
blackpepper
Oct 4, 2017 06:09 AM
o55ie18
Oct 5, 2015 05:50 PM
brandoni
Sep 30, 2015 07:48 PM
