anyone familiar with tps
Old Jun 19, 2008 | 07:47 PM
tylerxfire's Avatar
Default anyone familiar with tps
hi guys i am trying to figure out my nitrous, i have a zex kit and just installed all the wiring, power ground power to the arming switch and the wire off the box that goes to the output voltage wire off our cars tps. so i tried the yellow wire because i got a volt reading on it that fluctuated from lower numbers to higher when at wot. it needs to be a wire like that because it will activate the box at wot and not at anything else. it has instructions to follow to program the box so i did it and it worked, then before running the nitrous and fuel lines decided to make sure it was still good but the red light was on now instead of green and now it wont program agin, power is good, ground is good, the tps wires are snug i don't get it. am i using the wrong line, i don't think so. anyone have valuable info. here. now the box is clicking when i turn the power on and flashes every time i turn it on. do i have a bad connection or wrong line please help. i am getting power from my 12v ignition wire. that runs to the arming switch, seems to have power and everything just won't program now.
Old Jun 20, 2008 | 07:16 PM
ChuckNorris's Avatar
Default Re: anyone familiar with tps
What was the voltage range you were getting from the wire?
Old Jun 21, 2008 | 08:32 PM
tylerxfire's Avatar
good to go all figured out and hooked up. just needed to use the wire off the back of the gas pedal
Old Jun 21, 2008 | 09:03 PM
NeedsWings's Avatar
which wire was it? did you find the factory WOT switch wire?
Old Jul 3, 2015 | 04:36 PM
bdh's Avatar
bdh
So which wire was it
Need to know for my kit
Thanks
Old Jul 3, 2015 | 04:53 PM
RED DOG's Avatar
Thanks
I doubt you'll get your answer . . . You've posted on a thread that is 7 years old. Also Tylerxfire hasn't logged into the forum since July 2010. Just sayin' . . .
Old Jul 3, 2015 | 05:32 PM
bdh's Avatar
bdh
Thanks I guess I should've looked at the date
Franc Rauscher
Other Vehicles
19
Sep 13, 2015 11:31 PM
Aug 4, 2015 05:02 PM
axnguyen
Jul 21, 2015 11:41 AM
bdh
Jul 9, 2015 09:40 AM
