Chilled My Ride for $4.95
Old Aug 10, 2008 | 01:09 PM
BrianBrave's Avatar
<--- Huge Horsepower
Default Chilled My Ride for $4.95
Quick and easy way to get some extra air flow to your radiator during these hot summer days by re-mounting both horns from behind the grill and out of the air flow path.
Material you will need (about $4.95)
2 wires for new harness (18 Gauge will work - I used red and Black)
2 Female Spade Connectors
2 Male Spade Connectors
Tie-Wraps
Black Electrical Tape
Self-Tapping Bolt
Make a three foot harness with crimp type male spade connectors on one end and female spade connectors on the other. Wrap wires in tape.
Locate pre-existing mounting hole for passenger side horn. (smaller hole shown with screwdriver)
Connect the new wiring harness to passenger side horn. (easier to do it now) and re-attach the factory mounting bracket.
Bolt the passenger side horn in place and route the new harness connecting the spade connectors to the factory wiring harness. I used the tie-wrap anchor that was on the hood latch support and re-mounted it in the existing hole by the PS line to help secure the new harness.
Connect remaining factory harness connectors to the driver side horn and mount into place using the clamp bolt for the PS line and secure excess harness out of the way with tie-wraps.
A quick, simple and inexpensive way to help you get some added airflow to the radiator with out drilling holes, making new brackets or modifying the factory harness.
Old Aug 10, 2008 | 01:10 PM
BrianBrave's Avatar
Default Re: Chilled My Ride for $4.95
Old Aug 10, 2008 | 01:45 PM
SRT6nTulsa's Avatar
Thumbs up Re: Chilled My Ride for $4.95
Good thinking, Brian. After driving around in 100+ weather, I'm going to do this, too. Thanks for posting.
Old Aug 10, 2008 | 02:40 PM
BLKFIN's Avatar
ADDICTED TO BOOST
Great idea!
Old Aug 10, 2008 | 03:04 PM
BrianBrave's Avatar
I thought it might help out those running the NW design get a little more air flow to the radiator.
Old Aug 10, 2008 | 04:43 PM
MikeR's Avatar
Brian, that should work even better for me since I cut out the deflectors on the grill to let the air flow straight in. Thanks for another little bit of air to cool things with. I have the Johnson pump now and ordered the 28oz surge tank from JEGS to seperate the IC cooler from the radiator. Next will be some extra cooling coils to add in series with the HE going back to the IC. I think that will be my final IC cooling configuration. At least for now.
MikeR
Old Aug 10, 2008 | 06:01 PM
DesertFox's Avatar
I'm looking forward to making enough power where this will come in handy.
Old Aug 11, 2008 | 08:21 PM
BLKFIN's Avatar
ADDICTED TO BOOST
I did your mod tonight...It worked perfectly even with the Needswings, Thank you for sharing!
Old Aug 12, 2008 | 04:02 AM
GDC-SRT's Avatar
Great idea! could eliminate a hot spot in the radiator core!
Old Aug 12, 2008 | 05:31 AM
Stogey's Avatar
SWEEEET !
This will be my next mod along with cutting out the grille deflectors ! Austin has now been in the 100+ range for over 40 days now ! Whew !
Thanks for sharing.
Old Aug 12, 2008 | 09:30 AM
MikeR's Avatar
Here is what it looks like with the grill deflectors removed. Now all I have to do is add the extra cooling coil in the IC line in front of the radiator and get all that nice cool air.
MikeR
https://www.crossfireforum.org/forum...0&d=1218497354
Old Aug 12, 2008 | 06:53 PM
MikeR
My only concern is that a stone or object has a clear shot into the radiator with the grill mod.
Otherwise it seems like a good idea.
Old Aug 12, 2008 | 08:20 PM
MikeR's Avatar
I may look around for some type of mesh screen to put on the back of the grill to deflect the missles but still breath all the open air. Maybe something in black with 1/8" or so mesh.
MikeR
Old Oct 9, 2008 | 01:31 PM
waldig's Avatar
My posts about the Mod 4 heat exchanger and the 3 videos show how you can do the Brian 'like' thing and mount them on the driver frame using existing holes and wire length. You do have to pull the dirt shields and get under it but the install is easy. WOODY
Kodebuster
Nov 5, 2020 04:06 PM
brandoni
Sep 30, 2015 07:48 PM
atdavis2
Sep 21, 2015 01:25 PM
Bill F
South Forum
Sep 11, 2015 02:29 PM
Romio
Jul 24, 2015 07:03 AM
