Another Engine Build Thread
Old Aug 25, 2008 | 05:06 PM
TVT_DESIGN
Guest
Posts: n/a
Default Another Engine Build Thread
I know we've all seen these engines ripped down and such, but here's another one.
The engine will be going into my car as soon as everything is complete. I will give details of what we are doing as we go.
Basic idea is big, forged, and torquey!
Old Aug 25, 2008 | 05:30 PM
TruTaing's Avatar
Default Re: Another Engine Build Thread
I have a feeling there is gonna be mucho displacement! subscribed!
Old Aug 25, 2008 | 06:20 PM
Moparrbust's Avatar
Torquey huh........................stroker.
Old Aug 25, 2008 | 06:45 PM
BrianBrave's Avatar
<--- Huge Horsepower
GO man GO!!!
Keep this thread up todate - don't let it die like the V8 engine swap or the STR6 engine transplant................
Old Aug 25, 2008 | 10:00 PM
blkxfire05's Avatar
yeah lets see what this beast can do
Old Aug 26, 2008 | 11:34 AM
Jeep2Xfire's Avatar
Stroker or bored over?? Or both, even better Any teasers, spoilers, etc??
Old Aug 26, 2008 | 01:10 PM
TVT_DESIGN
Guest
Posts: n/a
I'll just say we are shooting for 4.0L with N/A pistons and 3.7L for the SC crowd.
Old Aug 26, 2008 | 01:23 PM
Jeep2Xfire's Avatar
How are pistons different between NA and SC?? Dish/Dome?? Or rings?
I thought the biggest thing for forced induction was cam duration and valvetrain.
Old Aug 26, 2008 | 03:54 PM
TVT_DESIGN
Guest
Posts: n/a
Compression ratio. You don't want 11.5:1 in a boosted app.
Old Aug 26, 2008 | 04:14 PM
Tazz's Avatar
I'd go for a 4.0 liter NA == if the clutch and 6spd would handle it !!!! Question is-- how much ????
Old Aug 26, 2008 | 04:37 PM
Jeep2Xfire's Avatar
Okay, so dish vs. dome, I was curious if construction was it. Hypereutectic, cast, and forged wouldn't really care. Well maybe the cast ones on second thought.
Old Aug 26, 2008 | 05:02 PM
TVT_DESIGN
Guest
Posts: n/a
We're taking deposits of First Born, family heirlooms, and italian sports cars. You can just go ahead and mail over the deed to your house while you're at it.
Old Aug 26, 2008 | 10:06 PM
ProjectMayhem's Avatar
Stroker kits are normally quite exspensive, getting your block resleeved for a bigger bore and stroked with forged pistons,rods,rings. I love it! Is this just for the TVT car or is this going to be a possible kit for the future.
Old Aug 27, 2008 | 04:37 AM
Cal_Cobra's Avatar
From: Brentwood, CA (no not the OJ Simpson Brentwood, the real city of Brentwood in NorCal)
The SRT enginees have dished pistons for 9:1 compression vs the N/A's 10:1 compression.
The pistons, crank, rods, etc., on the SRT are forged, not sure about the N/A's internals.
BTW why the 3.7L instead of a 4.0L for the SC crowd ?
Old Sep 8, 2008 | 02:10 PM
TVT_DESIGN
Guest
Posts: n/a
Got around to stripping the engine apart. Our test engine suffered some serious issues during its life. Crank siezed and 5 rods are bent really bad, 5 of the 6 pistons also have the rings fused in.
We weighed them and the stock piston and rod combo averages about 1000g without bearings, but with rings. They are actually pretty light, mostly due to the design. We are looking to keep the weight under 1000g with our larger forged pistons. That's basically all of the progress thus far.
As we delve deeper we'll report back.
Old Sep 8, 2008 | 02:52 PM
TruTaing's Avatar
What caused all the damage? Was this test engine an NA or SC'ed motor?
Old Sep 8, 2008 | 04:23 PM
TVT_DESIGN
Guest
Posts: n/a
Couldn't tell you. It was out of an 02 ML320. Basically everything is perfect except the rods and one cylinder wall. It's being bored out, so that isn't an issue for us.
Old Sep 8, 2008 | 04:27 PM
velociabstract's Avatar
Are you sure you want to build that one. I mean, seized crank, bent rods, fused rings? I hope the motor was a freebee. I guess you know what your doing, but I would rather start with something less trashed.
Les
Old Sep 8, 2008 | 07:13 PM
TVT_DESIGN
Guest
Posts: n/a
The block is the only thing to be reused. Everything is more or less for measuring. Engine was all of $200.00, so if it blows after one pass i could care less. I don't think it will, but we'll know for sure after it gets back from a trip to the machine shop.
Old Sep 8, 2008 | 10:24 PM
BlueStorm's Avatar
will you guys be offset grinding the crankshaft a couple mm?
