Factory Amp Problems
Old Sep 26, 2008 | 02:58 PM
Grant's Avatar
Default Factory Amp Problems
I'm having an extrememly annoying problem with the amp in the car. It keeps blowing fuse 23. If I leave the harness unplugged, I get about 12v at the harness, and everything looks fine. As soon as I plug the harness into the amp, the fuse goes.
I've taken the amp out of the car, and took the case apart to see if I saw anything obvious, but nothing really stood out.
If anyone has any other suggestions for something I might have overlooked, I'd love to hear them...
I've posted in the "For Sale" section too, if anyone has one they can spare.
Old Sep 27, 2008 | 05:42 AM
manisusmc's Avatar
Default Re: Factory Amp Problems
Xfire_Repair_8a-Audio.pdf
please see pages 4-6 to troubleshoot your problem
Old Sep 27, 2008 | 05:57 AM
Grant's Avatar
I actually downloaded all of the PDF files, and that's how I determined that I was getting 12v at the amp and that fuse 23 was the one that kept going out.
I was just wondering if it was possible that I had a wiring short somewhere else that could cause this? The fuse is fine if I check the voltage with a meter. But as soon as I plug in the wire harness to the amp, it goes.
I found an amp at a salvage yard, but they still want $150 for it!
Old Sep 27, 2008 | 03:19 PM
manisusmc's Avatar
there are more tests to do other than checking for 12 volts there, i think there was 3 or 4 more tests and then if you can't find the problem after those tests,then it suggests replacing the amp.
Old Sep 27, 2008 | 03:54 PM
stevieb's Avatar
I just bought a Denon amp on ebay (800 watt) for $120 maybe you should go this way
Steve
Old Sep 27, 2008 | 04:00 PM
Grant's Avatar
Yeah, I was just hoping to not have to rewire everything. If I replace the factory amp with an aftermarket, I'm assuming I'll either have to run all new speaker wires, OR hack into the factory harness for the speaker out wires?
I was planning on replacing the headunit soon with a bluetooth compatible receiver, but I hadn't really planned on doing anything beyond using the adapter to connect it to the factory harness and amp.
I'd like to be able to easily return it to stock if I ended up selling the car one day.
Old Sep 27, 2008 | 04:05 PM
stevieb's Avatar
I just fitted my new amp today.
If you have a new head unit to fit the wiring doesnt take long at all, and the sound is sooooooo much better!
Seriously though the standard amp aint that great.
Steve
NeedsWings
70
Mar 24, 2023 09:48 AM
gp1200x
Dec 6, 2015 12:59 PM
MAXIMUM
Aug 4, 2015 11:04 PM
mobilefitt
Jul 28, 2015 03:45 PM
pioneer4x4
Jul 27, 2015 02:04 PM
