DIY, if you dare, Nitrous Install
Old Oct 4, 2008 | 04:07 PM
TVT_DESIGN
Guest
Posts: n/a
Default DIY, if you dare, Nitrous Install
In prep for MIR on Oct 12th, I've decided to give the Crossfire a little juice.
Components:
Cold Fusion Nitrous 5 lbs Nitrous Bottle, $129.00, Q2
Nitrous Express Bottle Brackets, $51.66, Q2
Nitrous Express TPS WOT Switch, $103.33
MSD Digital Window Switch, $154.30
NOS 150 HP Nitrous Solenoid, $92.95
NOS 200 HP Fuel Solenoid, $122.39
NOS Nozzle, $33.95
NOS Jets, $8.95, Q4
Total so far: $904.04
Not including SS line and AN fittings.
This can be done cheaper, but the TPS and MSD unit are for added safety. And the 2 5lbs bottles are easier to hide then a 10 lbs bottle.
You will need larger injectors and tuning to run this properly.
We're aiming for 100-150 shot.
Old Oct 4, 2008 | 07:49 PM
newCrossfire's Avatar
Default Re: DIY, if you dare, Nitrous Install
tvt im trying to figure if i can runA 75 SHOT and keep a decent afr with my preexisiting tune and larger injectors? or will it have to be re-tuned.
Old Oct 5, 2008 | 02:46 PM
TVT_DESIGN
Guest
Posts: n/a
It depends on your tune and if you run wet or dry.
If you have larger injectors and a decent tune, nothing too drastic, then you should be fine with a 75 dry or wet shot.
With stock injectors you could get away with a 50 shot, but it needs to be wet to be on the safe side.
Old Oct 5, 2008 | 09:16 PM
itll definately be a wet shot. its not a custom tune just 300 dollar one.
Old Oct 6, 2008 | 07:13 AM
TVT_DESIGN
Guest
Posts: n/a
It really depends on what they did to the Fuel and Timing tables. Too little fuel and too much timing advance will not be a good mix for NOS, but great for N/A.
Old Oct 6, 2008 | 08:39 AM
cassidyrj1's Avatar
nice hiding spot but how hard is it going to be to get them out to fill them
Old Oct 6, 2008 | 04:17 PM
TVT_DESIGN
Guest
Posts: n/a
It'll take about 5 mins to unbutton the interior and pull the bottles. I don't expect it to be an everyday task.
The solenoids and nozzle are in. Just waiting on the lines and the electronics and this car should fly, or break.
Old Oct 6, 2008 | 05:54 PM
stryfox's Avatar
sounds like fun keep us posted!
Old Nov 23, 2008 | 06:10 AM
amick6534's Avatar
Any new news on this setup?
Old Nov 23, 2008 | 02:55 PM
RealSER's Avatar
Having run nitrous on previous project cars, I don't understand why you need larger injectors. You should be tuning AFRs with the nitrous/fuel jets, not with your fuel injectors. If you weren't running lean before the nitrous, a properly tuned system won't run lean with the same injectors installed. Now, for a 100+ shot, a new fuel pump I can understand Looks like a quality install, I'm impressed - Jay
syfi
Mar 28, 2026 04:14 PM
TerryR
Dec 13, 2019 03:27 PM
UNDER PSI
Nov 1, 2015 09:39 PM
2005 Ragtop
Oct 3, 2015 03:01 PM
ozkancab
Sep 25, 2015 10:55 AM
