Ecu
Old Oct 23, 2008 | 01:17 PM
Default Ecu
Can anyone tell me if it is possible to have a backup ECU that has been upgraded so you can swap out the performance one whenever you may want? Or if it is at least possible to have a backup ecu programmed and ready to go, in case of failure? I'm just concerned, 10 years from now, I might have an ECU failure and there will be no one around that can program a new one ????
Old Oct 23, 2008 | 01:56 PM
MikeR's Avatar
Default Re: Ecu
If you want to buy the extra ECU and have it programmed for your VIN, yes it would work. I tried swapping the ECU's between my two SRT's when I was having a startup problem(bad crank sensor). The car did not like that. It checked the new ECU and wouldnt do anything.
MikeR
Old Oct 23, 2008 | 02:49 PM
CrossfireLTD's Avatar
Cool Re: Ecu
Yes you can swap the ECU/PCM Module but you will have to have the VIN flashed in order for it to work. I recently sold a NIB OEM ECU/PCM to one of our forum members for $300.00, since I no longer own a Crossfire.
minimayhem
17
Jan 19, 2016 02:10 PM
RacerXofFL
Sep 15, 2015 05:00 PM
sk8erjosh09
Sep 4, 2015 09:24 PM
psuperti
Aug 30, 2015 12:08 PM
Bayukbros
Aug 28, 2015 08:59 AM
