Disconnecting Battery
Old Aug 28, 2015 | 07:43 AM
Bayukbros's Avatar
Default Disconnecting Battery
Morning,
2005 Roadster. Tpms system and getting the computer to recognize the new sensors.
433Mz / orig. Schrader. Installed new Schrader's all around 433Mz and no one including Chrysler can make the computer recognize them. Going one more round with Chrysler / they are using a TPM/RK analyzer VT-60 tool and will attempt to input manually ..
I read somewhere on here, that disconnecting the pos battery cable for 10 min. and reconnect will set the sensors? Already tried the Atec VT55 tool and the magnets and driving the vehicle etc. etc.,
Another question, REFLASHING THE ECU was suggested by Schrader and advised me to have Chrysler do that .. BY disconnecting the battery and reconnecting, WILL that RE-FLASH the computer and are there any security codes for the RADIO that have to be re-entered ? I did not see any of this in the owner's manual ... What else to expect after the battery is disconnected.? thanks for any info ..
I have read everything on this website regarding this issue ...
Old Aug 28, 2015 | 08:59 AM
Default Re: Disconnecting Battery
Disconnecting the battery is not going to make the TPMS system "learn" new modules.
If a Chrysler dealer equipped to set up Crossfires cannot make them work, go to a real tire shop - dealers just don't usually work out well. Having said that, I had to take my two Roadsters in when I swapped tires and wheels between cars, took my local dealer less than 5 minutes a car to "teach" each car it's new TPMS sensors. And that was in rural Georgia, where they seldom see Crossfires.
I think you are going to the WRONG dealer.
I have no idea if ours are 315 or 433 mHz, supposedly they are 433 mHz, but I can't say for sure.
blackpepper
Oct 4, 2017 06:09 AM
o55ie18
Oct 5, 2015 05:50 PM
rmcdaniel12
Sep 22, 2015 01:20 PM
tritongreen
Sep 18, 2015 07:32 AM
Valk
Sep 17, 2015 11:43 AM
