Mercedes Air Box W/CAI
Old Nov 12, 2008 | 04:39 PM
TVT_DESIGN
Guest
Posts: n/a
Default Mercedes Air Box W/CAI
We just finished up a customer's car (C-class) and was able to basically replace the intake tubes and keep the stock CAI induction.
Is there any interest in this for the Crossfire?
I would suggest upgrading to the MB box if so as the flow is almost double the Crossfire box.
Below are some pics.
Old Nov 12, 2008 | 05:22 PM
amick6534's Avatar
Default Re: Mercedes Air Box W/CAI
I have the MB cover what would be needed for conversion?
Old Nov 12, 2008 | 05:46 PM
TVT_DESIGN
Guest
Posts: n/a
I'll get the pipes fitted up to my car with the MB box.
Cost will be around 75.00 for a bolt on app.
Old Nov 12, 2008 | 05:58 PM
deloreanbiker's Avatar
I, too, have the MB box on my Ltd Coupe. Anywhere near the price you are quoting and I'll get on board.
Old Nov 12, 2008 | 07:00 PM
Alabaster04's Avatar
Would this setup work with the Stock Crossfire air box as well? $75, I'm on board!
Old Nov 13, 2008 | 07:25 AM
delornut's Avatar
I have the MB air box as well and for this price I want one too.
Bruce
Old Nov 13, 2008 | 10:36 AM
amick6534's Avatar
Anthony, you say that the flow is almost double. So with your new tubes how would this measure up to say the needwings cai? Thanks!
Old Nov 13, 2008 | 01:01 PM
Isellthem's Avatar
What he said! The MB airbox flows almost twice as well as the oem Crossfire? I thought below the surface they were pretty much the same.
Old Nov 13, 2008 | 01:11 PM
Kit Fox's Avatar
Ditto, interested too, I like the dual intake setup much more then single intake.
Old Nov 13, 2008 | 02:10 PM
lesr's Avatar
Can you give me an idea what the cost would be for this mod including a MB Box
Looks ideal to me,
Old Nov 13, 2008 | 02:54 PM
TVT_DESIGN
Guest
Posts: n/a
The filter area and tube diameter of the MB box is substantially larger then the Crossfire.
I'll post pics of the two pieces next to each other.
I'll also get total pricing after tomorrow's dyno session. No point in a price if we don't get good results...
Old Nov 13, 2008 | 04:41 PM
This is true. I could not use the XF tubes on my MB box. I had to get larger ones.
Old Nov 13, 2008 | 04:49 PM
Isellthem's Avatar
FP, I put an 320 SLK air box on my car and the tubes from the grill fit like oem. Which air box did you put on your car?
Old Nov 13, 2008 | 04:56 PM
I have a larger box that's not the SLK320. I think it's from the smaller V8. The pic on the first post is not from an SLK, and that's the one I have.
Old Nov 13, 2008 | 05:33 PM
FP - the MB airbox have on my 06 coupe looks identical to that in the TVT post and identical to yours except for the bling ( which I emailed you about ;-) ). My stock tubes also fit perfectly. Can you check yours and give a stock #???
Thanks.
Old Nov 13, 2008 | 06:30 PM
TVT_DESIGN
Guest
Posts: n/a
I believe the SLK320 box is the same size as the Crossfire box, but the C class box is substantially larger.
I think with the KN filters, intake tubes, and a gutted box we may surpass CAI numbers. There is a ton of flow through this box now.
Old Nov 13, 2008 | 08:58 PM
JimmySkullz's Avatar
Let me know the price for the M.B. box and tubes too..
Old Nov 14, 2008 | 01:34 PM
TVT_DESIGN
Guest
Posts: n/a
We picked up 7 RWHP on a 2.6L. This is with the MB airbox, KN filters, and modded tubes.
I would expect another 3-5 on our 3.2L motors.
CAIs usually record 8-12 RWHP, so this is a very good alternative.
Old Nov 14, 2008 | 02:15 PM
Okay - let me try again. Bought my MB airbox over the net and it appears to be identical to TVT's. I admit that there is a very slight difference between the fit of the tubes on the Xfire box and on the MB box I have, but nothing major. The tubes do fit, just have to take a moment or two in attaching them.That would seem to indicate that I have an SLK320 airbox, but I'd like to know for sure.
Anybody got a part number on the TVT or FP MB airbox????
Old Nov 14, 2008 | 02:38 PM
TVT_DESIGN
Guest
Posts: n/a
SLK320 is: 1120900501
C320: 1120901101
Siginificant differences in flow.
