Emulsion In The Oil Cap
Old Nov 18, 2008 | 09:19 AM
Kit Fox's Avatar
Default Emulsion In The Oil Cap
Anyone else experiencing it? I don't think I have a bad head gasket nor am I short on any coolant so I should be fine. I figure its just the fact that I don't drive long enough to properly heat the engine up. I'm not too worried about it but should I maybe drive the car around for abit of a longer trip from time to time in order to get rid of it?
Old Nov 18, 2008 | 10:48 AM
Stogey's Avatar
Default Re: Emulsion In The Oil Cap
If you don't drive the car much, could be condensate, but I'd for sure keep an eye on the coolant tank !!!
Old Nov 20, 2008 | 05:03 PM
Another good place to look for emulsion or rust is on the insde of the oil dipstick cap.
Old Nov 20, 2008 | 05:09 PM
GB'sXFire's Avatar
I don't like the looks of that. I'm gonna go google "how to tell if oil is mixing with water in my car" or something like that. I'll post back if I find anything. I thought there was a kit you could use to check for this. I remember way back when you could have your oil analyed to see what was in it. Don't do that anymore 'cause I sold all my muscle cars .
Old Nov 20, 2008 | 05:28 PM
GB'sXFire's Avatar
Ok, in my quick google search, I found a comapny, EliteETC.com, that if I read it right, looks like they can analyze oil for $15. Google baby, Google! I love Google. Quick story, off topic, but when I was looking at XF's to test drive/purchase, the sales guys always tried to pressure me into buying their cars. I always told them, "Look. I'm not buying a car today without further research. My last BBQ I bought, I researched for 8 weeks before making a final decision, I'm certainly not buying a car without more research on your car". Ok, back to the subject at hand. TY. LOL
Old Nov 21, 2008 | 09:58 AM
BlueStorm's Avatar
what is your climate like? temp, humidity?
I would pull a valve cover and take a peak inside.
Old Nov 21, 2008 | 10:23 AM
I had it on a GMC engine 4.3L V six. By the time I found the cause the engine was ruined and had to be rebuilt. All the sludge had filled the oil channels and stopped lubrication to vital areas. It was the gaskets under the heads. It was a slow leak, but very damaging. Good luck, do not drive it until you find the cause. I do not think it is low milleage driving.
Old Nov 21, 2008 | 11:52 AM
Stogey's Avatar
Condensate is not highly unusual, however as suggested I would pull a valve cover and check underneath.
Old Nov 21, 2008 | 05:00 PM
BlueStorm's Avatar
get an oil pressure reading too.
Old Nov 24, 2008 | 08:57 AM
Kit Fox's Avatar
Taking the valve cover sounds like quite a hassle, I'm gonna look into having my oil analyzed. I'm in Chicago and it recently started getting ultra cold. When I opened the oil fill in cap the engine note did change abit after a few seconds, not sure if thats related.
Old Nov 24, 2008 | 12:32 PM
Kit Fox's Avatar
None there.
Old Nov 24, 2008 | 12:35 PM
Kit Fox's Avatar
Originally Posted by GB'sXFire
Ok, in my quick google search, I found a comapny, EliteETC.com, that if I read it right, looks like they can analyze oil for $15.L
AVIATION USE ONLY
Old Nov 24, 2008 | 12:38 PM
Bladecutter's Avatar
I've used Blackstone Labs for oil analysis on my Nissan Altima since I bought it new in Dec '06.
http://www.blackstone-labs.com/
They are very quick with getting the results back to you after doing the tests, and the writing is very easy to understand.
BC.
Old Nov 24, 2008 | 05:48 PM
BlueStorm's Avatar
you could try using a by-pass filter from FRANTZ. it uses a paper roll, which absorbes about 1 cup of water, thus drying your oil for lower acidity and better filtration. http://www.wefilterit.com/
Old Nov 24, 2008 | 07:55 PM
beanerneon's Avatar
you dont get the oil hot enough to get the moisture out. ive seen that in v8s and they were fine but i drive mine longer so that it gets hot
Old Nov 25, 2008 | 08:54 AM
Kit Fox's Avatar
Whats a recommended time to properly heat the engine up and get this junk out.
Old Nov 25, 2008 | 09:16 AM
beanerneon's Avatar
i let mine get all the way hot and run it warm
Old Nov 25, 2008 | 09:57 AM
BlueStorm's Avatar
drain the oil and filter first
Old Nov 25, 2008 | 11:34 AM
Warm engine, then drain oil and change the filter. Repeat a few weeks later if you want to be really thorough.
Old Nov 25, 2008 | 11:37 AM
patpur's Avatar
Senior Member/Moderator
Can't help you with what it is but I can tell you I too drive short distances, only 9300 miles on my 05 and no emulsion. I've done 3 oil changes so far.
Pat
