Stock subwoofer replacement question(s).
Old Nov 20, 2008 | 11:40 PM
brian_omeara07's Avatar
Thumbs up Stock subwoofer replacement question(s).
http://cgi.ebay.com/KICKER-04SSMB6-6-5-MIDBASS-SPEAKER-SUBWOOFER-WOOFER_W0QQitemZ170266979301QQcmdZViewItemQQptZCar _Subwoofers_Enclosures?hash=item170266979301&_trks id=p3286.c0.m14&_trkparms=72%3A1234|66%3A2|65%3A12 |39%3A1|240%3A1318
Kicker 04SSMB6
Anyone have experience with these or subs of similar mounting depth? Basically I have a surplus of Audio equipment, but I really don't feel like putting a Fi 12 in this vehicle...I'll keep that for the dB drag one.
My Situation:
I have a separate two channel amp I will be using for these subs (will push them JUST fine.)
I will be running the stock setup on the rest of the system, via the SD card Clarion that has been discussed here.
My Issue:
Anyone replaced the stock subwoofers before?
Will they fit or will it require some hacking?
Is it difficult, (i.e. - what panels need to be removed and how).
Is is safe to drill near that area for wire threading? (Or does anyone have a suggestion of how to wire the stock locations with an aftermarket amp?)
My Ultimatum:
I do plenty of car audio work, so don't feel the need to simplify for me.
I only HEARD that the stock subwoofers were 6.5's, if I'm wrong by all means correct me.
And finally, biggest pet peeve for me in forums... Yes I searched.
Thanks for any help
Old Nov 21, 2008 | 05:47 AM
bombsquad56's Avatar
Default Re: Stock subwoofer replacement question(s).
Yes, the factory subs are 6.5". They are easy to replace but the performance gain would be small at best. I say this because they simply use the non sealed empty space around the fuel tank for their enclosure. You'll have to remove the carpet panel behind the seats to access the subs. Any drilling should be done carefully as the fuel tank is located behind the seats just millimeters behind the sheetmetal.
Old Nov 21, 2008 | 01:43 PM
faiz23's Avatar
i know you said you searched but try harder next time
https://www.crossfireforum.org/forum...ghlight=kicker
https://www.crossfireforum.org/forum...ad.php?t=27784
Old Nov 21, 2008 | 03:08 PM
Originally Posted by faiz23
gahhh i typed "stock subwoofer" into the string and used title only. FOILED! haha thanks!
Still one question remains. The kickers that bhays used are 2 7/8" mounting depth, and these are a 2 1/4"...so i should have 2/8" room left correct? so the question is...
Is the cabinet that these subs sit in worth dynamatting or not entirely?
Old Nov 21, 2008 | 05:18 PM
Mr. Max's Avatar
NOW THAT DESERVES A WARNING STICKER! Think I can figure out all those other stupid ones.
Old Nov 21, 2008 | 05:26 PM
SRT6nTulsa's Avatar
The factory subwoofer is a dual 2 OHM, 7 inch woofer. They are the pair closest to the camera.
Old Nov 21, 2008 | 05:28 PM
SRT6nTulsa's Avatar
It is not worth dynamatting. The rest of the car, is a different story:
http://www.rightclicktexas.com/aa/ze...ler-crossfire/
Old Nov 30, 2008 | 02:22 PM
Tazz's Avatar
Novice here at speaker install -- stock subwoofers have four wires, my Kicker replacements have only two -- how do I wire them ?? Thanks,
Old Nov 30, 2008 | 03:53 PM
ppro's Avatar
Two of the wires are power; two are signal. Refer to the factory wiring chart to identify them (on one of the threads - search and see https://www.crossfireforum.org/forum...ad.php?t=20949)
I didn't bother removing the factory subs - left them in place. Instead ran a separate pair of leads to a powered sub. But that's using a replacement head unit so probably not much help to you.
If I was doing it with the factory head unit, I would come off the head unit before the factory amp, go into the SD Clarion card, then to the power amp you have, then to the speakers, put into enclosures and bolted to something solid (not the carpeted trim panels). That's just me.
KDW4Him
18
Sep 1, 2021 05:47 PM
gblack32
Sep 7, 2016 08:27 PM
michaelcycle58
Jul 28, 2015 08:12 PM
axnguyen
Jul 21, 2015 11:41 AM
