p0140 code
Old Nov 28, 2008 | 01:05 PM
ryan48's Avatar
Default p0140 code
It appears my secondary air pump is bad. Does anyone know if it falls under the epa warranty?
It seems to cover the ecu coverage of the pump, but not the pump itself...hmm
What Are Specified Major Emission Control Components?
There are three specified major emission control components, covered for the first 8 years or 80,000 miles of vehicle use on 1995 and newer vehicles:
  • Catalytic converters.
  • The electronic emissions control unit or computer (ECU).
  • The onboard emissions diagnostic device or computer (OBD).
Catalytic converters are critical emission control components that have been installed on most cars and trucks manufactured since 1975. Since engines don't burn fuel completely during the combustion process, the exhaust contains a significant amount of harmful pollutants such as carbon monoxide, hydrocarbons, and oxides of nitrogen. The catalytic converter aids the conversion of these pollutants to less harmful substances such as carbon dioxide, water vapor, nitrogen, and oxygen before the exhaust is expelled into the environment.
The electronic emissions control unit or computer monitors certain powertrain functions and controls various operating parameters to help the vehicle run efficiently and with the lowest possible emissions. Ignition, transmission function, air injection, exhaust gas recirculation (EGR), engine operating temperature and fuel system parameters are some of the systems monitored and/or controlled by the electronic emissions control unit.
Old Nov 28, 2008 | 01:08 PM
manisusmc's Avatar
Default Re: p0140 code
https://www.crossfireforum.org/forum...ad.php?t=28208
try this and no it's not covered by the emmisions warranty
rampntlion
21
Feb 11, 2019 08:18 AM
TOPLESS
Feb 9, 2016 11:28 AM
crossfireusa
Oct 28, 2015 12:03 AM
tritongreen
Sep 18, 2015 07:32 AM
MickeyNasty
Sep 6, 2015 08:29 PM
