"Auto" lights
Old Jan 3, 2009 | 06:32 PM
TaReGt's Avatar
Exclamation "Auto" lights
Is it possible to make lights (headlamps) to turn on automatically when you turn on your car and to turn them off when you turn your car off ?
Old Jan 3, 2009 | 06:44 PM
Beaner's Avatar
Default Re: "Auto" lights
Sure, buy a car from Canada. I have not touched the light switch unless I want the fog lights to turn on.
Old Jan 3, 2009 | 06:49 PM
TaReGt's Avatar
Com on...Seriously...How to do that?
Old Jan 3, 2009 | 07:41 PM
GDC-SRT's Avatar
The U.S. cars do not have the same light configuration as the ones for other markets.
Not sure if it just the light switch. Try and search the forum it has come up before.
Old Jan 3, 2009 | 07:48 PM
70GT6's Avatar
Isn't that just daytime running lights? It does not turn on the taillights and side lamps. (dealer can turn on/off this feature)
You could easily power the light switch through a relay that turns on and off with the ignition. (just leave the switch on or bypass it)
Old Jan 3, 2009 | 07:51 PM
TaReGt's Avatar
Finally...Can you please explain me how to do that ?
Old Jan 3, 2009 | 08:10 PM
In Canada we use daytime running lights, the XF lights all come on including rear, plate and side markers. The high beam does not work though until you turn on the regular switch, you can still flash the highs as normal.
Cars coming into this country from the US have to be reprogrammed to do this. A lot of cars in Canada have just the lows on half power for daytime running lights but not the XF. If you want daytime running lights in the US, then a dealer should be able to do it if it is legal. This is what I understand.
Old Jan 4, 2009 | 09:55 PM
Voyager's Avatar
i want the same auto lights like my jag, when its dark the lights come on and when you turn the car off they turn off. that way you don't ever have to mess with the switch and never have to worry about leaving them on when you leave your car
Old Jan 5, 2009 | 04:40 AM
martosh79's Avatar
It is very simple. You have to go to your dealer. they will plug the check up box ( what ever thing they use to check your car set ups) and they can change the parameters of the lights ,etc.
In Finland you have to drive day and night with the headlights on. So in every car sold in finland the lights are on or off automaticly. I have done it afterwards in the dealers shop. They say it is really easy and it only takes like 5 minutes. The thing they can't do is to programm them to shut down after 20 seconds. That configration is not possible like in the mercedes or bmw's.
Old Jan 5, 2009 | 04:52 AM
To do this you need a sensor to detect the light level, many cars have this these days, this includes cheap cars as well, I find that I can still manage to turn that switch though when I sense it is dark. The feature where the lights stay on for a while after turning off the ignition is real handy, having them turn on automatically not so much.
Old Jan 5, 2009 | 06:43 AM
rcompart's Avatar
Source the sensor from a Pontiac Grand Prix. It's very straight forward. If my memory serves me correctly, it will have 4 wires coming out of it, constant +, switched +, ground and a wire that will read ground when its dark and open when it's light.
Old Jan 5, 2009 | 08:48 AM
TaReGt's Avatar
So? Can someone finally explain me what should i do, except to go to chrysler?
Old Jan 5, 2009 | 04:12 PM
crossfirefrank's Avatar
I agree I also would like the auto lights. Both my other cars have them and I have forgot to turn the lights off and drained the battery more than once since I've owned it. I'm sure in time someone will come up with a mod. for this.
Old Jan 8, 2009 | 12:20 AM
brian_omeara07's Avatar
Rcompart already did i think haha, no mod just messing with relays.
Old Jan 8, 2009 | 08:24 AM
TaReGt's Avatar
Ok...so can someone explain?
Old Jan 8, 2009 | 08:36 AM
patpur's Avatar
Senior Member/Moderator
TaReGt - It sounds like you have to go to your dealer to have this done. After reading through the posts its seems its understood how it works but not how to do it yourself. If I were you I'd contact my dealer and ask him if he knows how to do it.
Pat
Old Jan 8, 2009 | 08:56 AM
TaReGt's Avatar
I understood that i have to go to chrysler dealer, but some people mentioned that "someone did it" and "that is possible to connect it to light sensor" so i was waiting for people to explain.
Old Jan 8, 2009 | 09:07 AM
I agree with patpur, see the dealer and get daytime running lights configured.
Daytime running lights on the Xfire have all the lights on except that the high beams and fogs will not work until you turn the switch.
The sequence with the light switch off is as follows:
Ignition on ... All lights on except for the low beams.
In gear/ drive with hand brake on ... All lights on except low beams.
In gear/drive with hand brake off ... All lights on, high beam/fogs not operable, except for the high beam flash function.
Getting out of the car with light switch still in the off position... shutting door turns on all lights again, low goes off and the fog lights come on for a few seconds and then all the lights go out.
Thats what seems to happen to my car with daytime running lights. My car is a six speed and the auto tranny sequence I assume is the same.
2004_
Jul 9, 2025 12:39 AM
jgreen
106
Sep 18, 2017 11:46 PM
xfClifford
27
Nov 10, 2015 10:08 PM
KwehCat
Jul 16, 2015 04:48 PM
