Car Door Closing Sound
Old Feb 14, 2009 | 09:26 PM
TheDon's Avatar
Default Car Door Closing Sound
Not really a problem, but more so a nuisance I have.
My passenger door sounds great. The door shuts solidly with a deep thump, like that of a Mercedes or Jag.
My driver door sounds like tin when I close it. It's loud, sounds cheap, and has a bit of a rattle.
Coincidently (not so much), this is the door that has slight wind noise on the highway.
Anyone have any ideas for a fix?
Old Feb 14, 2009 | 10:08 PM
alfdoc's Avatar
Default Re: Car Door Closing Sound
It sounds like the window regulator is loose and out of adjustment. check the service bulletins section of the forum, there's one for the window there. I had to do my own drivers door window regulator adjustment after the dealership changed the regulator. It was way out and the mechanic apparently didn't check his work after he was done. It takes a little time and patients to do and get it right .
Old Feb 15, 2009 | 07:38 AM
maxcichon's Avatar
I had to have mine tightened twice. Brought my own Loktite the second time.
Pretty common problem...
Old Feb 15, 2009 | 08:41 AM
TheDon's Avatar
You had the window regulator tightened twice, or your door itself?
Old Feb 15, 2009 | 08:44 AM
maxcichon's Avatar
Window regulator mount. Inside the door.
Yep, twice. That's the time the service writer talked the service manager into buying me breakfast at iHop for having to drive all the way back for their mistake. Nice guys!
Old Feb 15, 2009 | 08:54 AM
TheDon's Avatar
Thanks guys. I've searched for a TSB with no avail, any links?
Old Feb 15, 2009 | 12:03 PM
robby363's Avatar
You can find the TSB files here. https://www.crossfireforum.org/forum...ad.php?t=13875
Old Feb 16, 2009 | 06:30 PM
Kurts's Avatar
Could also be the padding within the door.
After the Coupe was whacked by a deer a couple of years ago within several months I noticed that the door sounded tinny when closed. There were times when it made a nice "dong" sound when closed, like someone smacking a giant gong.
Took it back to the body shop that did the initial repair & had the car back within a couple of hours. The service manager said the the door insulation had fallen off. They just glued it back in position and voila', end of issue.
Old Feb 22, 2009 | 04:34 PM
To see if the problem arises because of the window fitting wrongly, put both of the windows down and compare the sound of each door closing. If they sound the same then it is the window that is to blame. An air tight door sounds different than a door that is poorly sealed.
rayth
41
Jul 31, 2019 04:02 PM
gobraves423
Jun 6, 2015 07:03 PM
X-fired
Aug 28, 2003 11:34 AM
mouserider
Jul 26, 2003 11:47 PM
chuckhaze
Jul 1, 2003 02:48 PM
