Tensioner pulley removal
Old Feb 21, 2009 | 01:05 PM
crookedview's Avatar
Default Tensioner pulley removal
Hello,
Looking for a little advice..
I'm replacing my alternator, and need to remove the tensioner pulley. Has anyone done this, if so, how did you go about it? I'm reading the service manual and it says it can cause damage to hands so I want to make sure I'm not going to crush my fingers or something.
Thanks for any help,
Chris
Old Feb 21, 2009 | 01:29 PM
Default Re: Tensioner pulley removal
why do you want to remove it ,, if to get the belt off a #10 torq socket with a ratchet and move it like you would undo a bolt do not remove the nut,,, i will send you a pm and you can call me or send me your # jim
Old Feb 21, 2009 | 03:37 PM
Jim,
How late you going to be around? I'm going to run to the auto parts store for a few Torx sockets and some other stuff.
I'll call, but want to make sure it's not too late.
Thanks,
Chris
Old Feb 21, 2009 | 04:40 PM
9 :30 to 10 florida time,,, any time up to that is fine jim
Old Feb 21, 2009 | 06:25 PM
Ok guys, having a little trouble here.
This is the tensioner pulley, correct?:
I'm not sure if it's the same on the NA as the Supercharged engine, but how do I loosen the tensioner enough to remove the belt from the alternator?
Old Feb 21, 2009 | 06:43 PM
Look in the mirror...
Old Feb 21, 2009 | 06:52 PM
Old Feb 21, 2009 | 07:04 PM
Fantastic, got it!
Thanks guys. Now any tips to get this alternator out easily? :\
Old Feb 21, 2009 | 07:08 PM
Just glancing at mine, it looks like two inverted torx bolts and it should drop down, tilt it forward to disconnect the wiring. |You may have to push a couple coolant hoses out of the way.
It doesn't look too hard really. Be sure to disconnect the battery.
James
PS E14 socket
Old Feb 21, 2009 | 09:39 PM
Hahahaha it's ALLIIIIIVE!! No more pesky bearing growl!
Thanks for everyone's help, couldn't have done it without you guys .
Oh, and for future reference, there are little brass spacers around the two bolts holding the alternator in place - which were also somewhat holding the alternator in place after I had removed the bolts - all you need to do is use something to compress the spacer (I used a vise grip) and jiggle it around to loosen it.
If anyone needs help replacing the alternator on their NA Crossfire, I'd be more than happy to help! Need to return the favor .
Old Feb 21, 2009 | 10:10 PM
Quite common on all manufacturers, except they are usually not brass. Glad you got it finished. |James
Old Feb 21, 2009 | 10:22 PM
Ehhh, not really sure if they're brass, but they're colored like it.
onehundred80
Aug 6, 2016 12:03 PM
smokey847
Nov 12, 2015 11:54 PM
BEATv1
Sep 10, 2015 12:58 PM
xfireohio
Sep 8, 2015 04:33 PM
jaesa
Sep 7, 2015 01:50 PM
