Need Help Radio goes out when pushed hard
Old Mar 8, 2009 | 06:28 PM
boom182's Avatar
Default Need Help Radio goes out when pushed hard
Did any of you experience this? When I pushed my car hard the radio started to Flicker on and off. Also the battery light came on.
Old Mar 8, 2009 | 06:48 PM
billangiep's Avatar
Default Re: Need Help Radio goes out when pushed hard
If you haven't already you might check the batt. terminals for corrosion, loose wires from the alt. ect. Also depending on the age your battery it may be at the end of it's life?
Bill,
Old Mar 8, 2009 | 07:53 PM
danhaman's Avatar
Bill,
Shouldn't be the battery should it? Should be powered by the alt while running. If the alt is being over tasked it wouldn't be able to charge the battery and then your electrical system might suffer but I'd expect to hear this problem a lot if the alt's aren't very powerful.
Maybe it's just that your alt is failing?
My two cents.
Dh
Old Mar 8, 2009 | 08:05 PM
lowwkeyy's Avatar
If you are not having any other issues and u have checked the bat connection remove radio if used car look for stupid self install radio issues loose or shorted cable if not. Keep radio out and drive hard see if bat goes dumb again I assume u mean hard foot to floor not pushing ur audio
Old Mar 8, 2009 | 08:08 PM
parawxman's Avatar
Have had the same problem when the car was pushed, the problem has progressed and happens under all driving now. The radio doesn't go out entirely, only greatly muffled. Suspect it is a loose connection at the radio, banging on the side of the center console restores temporary use. Battery light does not flicker
Old Mar 15, 2009 | 04:14 PM
Serendip's Avatar
I might be getting to the party late, but here is my experience.
I bought my 2007 coupe in January, over the phone from a dealer in Michigan (I'm in KY). I flew up, did the paperwork, and hit the road headed home in cold, cold weather. I noticed that the cd player would stop running for a few seconds when I would turn on lights, seat warmer, anything electrical. That seemed odd and concerned me, but my override concern was to get home.
After about an hour, missed meals caught up to me and I stopped for a bite. Back in the car, the dash lit up strangely and the car refused to crank. After fooling around with it a bit, everything went dead.
I surmised that the car, which had sat unsold for over a year, including through some very cold weather lately, had suffered a weakened battery that gave out after being charged and run for an hour. It cost me a night in Findlay, Ohio, but the local dealer replaced the battery the next morning, and Monroe Dodge--where I bought my car--even paid for my motel, so I can't complain. In fact, I now have a fresh battery.
Anyway, it sounds to me as if you are experiencing the same symptons. I know it seems unlikely since your alternator should be carrying the load, but strange things do happen.
Good luck.
aerobluehal1
Canada
19
Oct 13, 2018 09:47 AM
blackpepper
Oct 4, 2017 06:09 AM
Sterling57
Apr 11, 2016 06:11 PM
brandoni
Sep 30, 2015 07:48 PM
Selbyl
Sep 26, 2015 04:15 AM
