Fan is incredibly loud...
Old Mar 19, 2009 | 03:32 PM
hocke5716's Avatar
Default Fan is incredibly loud...
Hoping someone could help me out.
The car was running completely normal. Now after its running for a few minutes the fan turns on excessively high, making a very loud sound that is heard within the cabin easily.
I disconnected the battery then reconnected and it stopped the problem, only to recur again the next day. Now that method has no effect.
Thanks for any help. :-)
Old Mar 19, 2009 | 03:47 PM
LantanaTX's Avatar
Default Re: Fan is incredibly loud....
I am pretty sure the fan is two speed. It goes on high when temps are high and/or the a/c is on. If the fan is just on high it is probably working fine, but you could have a problem with the coolant thermostat or be low on coolant. If it is just making a lot of noise, it could be a bearning in the fan motor going bad. Mine goes on high when sitting in traffic on a hot Texas day or afer running the car hard, I can hear it come on.
Old Mar 19, 2009 | 03:56 PM
kingkub57's Avatar
There are two electric cooling fans for our cars or a two speed single fan not sure one speed is for normall operations and then the other one kicks in when engine is very hot, which is much louder than the regular one, the second one should cycle on and off, when engine temp rises then goes back down to normal temp. If it is extreamly loud it could be off balance, check the blades for blades cracked/damaged, or if there is any kind of undercoating on it.
Old Mar 19, 2009 | 06:02 PM
waldig's Avatar
Talking Re: Fan is incredibly loud...
The SRT has a single speed fan motor. The speed is controlled by switching power supply that varies the applied voltage to control speed. I have monitored some of this and seen that the control gives about 4 volts to start and can go up from there. Near the 12volt range of operation, the fan makes more noise than than a Saturn rocket.
If your speed of the fan is too high under normal heat conditions, the fan controller may be too going around the bend and need replacement. The controller is the box with the fins on the drivers fender.
Woody
Old Mar 19, 2009 | 06:59 PM
hocke5716's Avatar
Awesome, ill def. look into those things.
Appreciate the input. :-)
Old Mar 20, 2009 | 08:34 AM
SNAKEWOLF's Avatar
Look At The Section 7 Service Manual
You Can Down Load Manual From Srt Sight
Good Luck
Old Mar 20, 2009 | 10:37 AM
Woody
I assume you mean variable speed controlled not single speed.
Old Mar 20, 2009 | 12:33 PM
Crossfireone's Avatar
Before you start throwing parts at the car, see if someone you know has a scan tool that can take a live (snapshot) picture as your car is running & focus in on the ECT (engine coolant temp. sensor) to make sure it isn't reading too high & fooling the fan to run the high side of it's variable speed. This sensor should cost a lot less than the fan circuit parts. Let us know what solves your prob.
Old Mar 20, 2009 | 02:13 PM
sonoronos's Avatar
Please check your coolant level. The first thing to check when a car overheats or the radiator fan is noticeable more often than usual is low coolant level.
Old Mar 20, 2009 | 02:57 PM
waldig's Avatar
The motor speed is controlled by the variable voltage applied for the controller. There are not several windings to switch from. Enjoy,
W KEND W DY .
ENJOY
Old Mar 21, 2009 | 06:16 PM
WEKEND WDY .
ENJOY
My term explains what it is in three words, not two words that require an additional sentence to explain that it is not quite what I said it was.
I like your script, so I am going to use it rather than this shi##y spider leg script that is the default script. You have got style too, keep it going.
PS I had to use one of your images as we can only have four per thread.
Old Mar 21, 2009 | 07:17 PM
GDC-SRT's Avatar
Are you sure it is the cooling fan?
https://www.crossfireforum.org/forum...air+pump+noise
Valk
Jul 12, 2021 09:49 PM
Nov 11, 2015 05:22 AM
Oct 1, 2015 01:42 AM
RiderJC
Sep 7, 2015 11:19 PM
williammt
Sep 6, 2015 11:23 AM
