Timing belt
Old Apr 17, 2009 | 07:12 AM
rock's Avatar
Default Timing belt
I searched, but couldn't get a definitive answer. When is it recommended that the timing belt is changed on our Crossfires (I have a NA if it makes a difference)?
Old Apr 17, 2009 | 07:28 AM
Stogey's Avatar
Default Re: Timing belt
If I'm not mistaken, our engines use timing chains instead of belts, so there would be no issue of replacing belts at certain mileages. Those forward thinkin Germans ....eh !
Old Apr 17, 2009 | 07:32 AM
LantanaTX's Avatar
Are you talking about the rubber drive/fan belt or the timing chain that drives the cams? Timing chain? Probably never. Rubber drive belt? Not sure of the reccomended change, but inspect it for cracking and change if it shows signs of wear or cracking.
Old Apr 17, 2009 | 07:37 AM
rock's Avatar
I was talking about a timing belt specifically, which, apparently, Crossfires don't have. Since you mentioned it, though, what about the serpentine belt? 60,000 miles, or as Lantana suggests, whenever visual inspection indicates that it is necessary?
waldig
Jul 31, 2017 09:46 AM
UNDER PSI
Aug 1, 2015 02:11 AM
waldig
Jul 30, 2015 07:39 PM
autumnmass
Jul 30, 2015 01:06 PM
Tp'sfury
Jul 17, 2015 01:15 PM
