Running wiring for sub into back???
Old Apr 30, 2009 | 12:42 AM
cardboardboxer's Avatar
Default Running wiring for sub into back???
hey i see a lot of you guys have put systems in the "trunk" and i'm working on it right now. I got through the firewall by the battery thanks to you guys...but i never seen any comments on how to get from behind the seats into the back, and i didn't feel like tearing up everything just to maybe find the right hole..... any help would be greatly appreciated thanks
Old Apr 30, 2009 | 04:15 AM
bluecoupe's Avatar
Default Re: Running wiring for sub into back???
There should be enough passage near the seat belt mount. You'll need to remove the trim pieces, weather stripping and pull back the carpeting from the bulkhead. I used this access when I wired up my reverse signal for the nav unit. Good luck!
Old Apr 30, 2009 | 04:20 AM
hey thanks i thought about trying that but just wasn't sure enough to commit i was getting tired i has already installed aftermarket head unit and just wanted to make sure the sub/amp was going to work so i just looped over the bulk head then spent the rest of the day sporting around like a school girl with a pretty new pet
Old Apr 30, 2009 | 04:28 AM
bluecoupe's Avatar
Caution, there's a "hidden" philips head screw that holds the seat belt trim piece on. It's located on the inboard side of the opening, you can access it better after removing the plastic bezel....careful not to break!
Kodebuster
Nov 5, 2020 04:06 PM
Hoppy
Dec 7, 2018 07:36 AM
axnguyen
Jul 21, 2015 11:41 AM
bdh
Jul 10, 2015 11:22 AM
bdh
Jul 9, 2015 09:40 AM
