2 different radios?
Old May 6, 2009 | 01:24 PM
Romio's Avatar
Default 2 different radios?
I have a 2004 coupe. An early one.. 2050th to be exact. I recently had to have to radio replaced under warranty because of loud static when playing CD's. But they didn't put the same radio back in. It looks identical but some different features. Before i used to be able to press the last button on the bottom when playing a CD to select a track. Above the last button had a down arrow. When i hit it the numbers 1-9 then 0 would come up. I could hit 1 then 2 and it would jump to track 12. Or just hit 7 to go to 7. But now that they replaced my radio. it looks the same but doesnt have this feature. I looked in my manual and it doesnt mention that feature at all. If they switch the radios on later models or something?
Old May 6, 2009 | 03:51 PM
eeric's Avatar
Default Re: 2 different radios?
In late 2003 there was a TSB for swirching out the radio (something with display).
To my knowledge the only difference with the radios is the added option with navigation. Did your first radio have navigation or better, does the new radio have it? If you have there should be a "nav" button on the top right.
Old May 6, 2009 | 07:01 PM
ppro's Avatar
I think the TSB had to do with the display being hard to read. The NAV radio is an upgraded version available as part of a package or as an option.
It might be that there were running changes in the radio and your early car had a version that was deprecated (made obsolete) by later ones.
Old May 7, 2009 | 11:06 AM
Romio's Avatar
nope, never had nav. along to top I have. TP, Aud, OPT, CD, FM, AM.
Old May 7, 2009 | 06:22 PM
bluecoupe's Avatar
Becker USA lists two models for the Crossfire. BE 6806 and BE 6811 (navi unit). I suppose it's possible there may have been 2 ver. of BE 6806?
Old May 14, 2009 | 03:55 PM
Don in Virginia's Avatar
There are 3 different radios. There is also as BE6812.
Old May 14, 2009 | 06:22 PM
bluecoupe's Avatar
Uhm, I wonder which one that is? I know the European Nav unit is BE 6810, 'cause I had one! I wonder what he model # used "down under" is?
Old May 14, 2009 | 10:29 PM
BE6812 is the one with the black *****.
Old Aug 12, 2009 | 08:15 PM
"Down under" the model number is OI89
aerobluehal1
Canada
19
Oct 13, 2018 09:47 AM
Sterling57
Apr 11, 2016 06:11 PM
smokey847
Nov 12, 2015 11:54 PM
brandoni
Sep 30, 2015 07:48 PM
Selbyl
Sep 26, 2015 04:15 AM
