Noisy clutch??
Old May 8, 2009 | 05:39 PM
Ecosse_Cross's Avatar
Default Noisy clutch??
My 2005 manual transmission Crossfire (60k miles) has developed a weird noise which is (I think) something to do with the clutch/flywheel action. When I engage the clutch there is a low pitched 'metallic' grinding noise which I can only describe as sounding like something loose or needing adjusting. It is most noticeable in slow stop-start traffic when the engine has warmed up (don't hear it when cold at start up) and when engaging low gears (especially 1st or 2nd). I've also noticed lately that the noise can also sometimes be heard at low crawling speeds in traffic in 1st or 2nd gear even when the clutch is not engaged.
Does anyone have any ideas what might be the cause? Would it be worth checking the clutch fluid level? If so how do I do this? Or does it sound like a new clutch or flywheel is on the cards? Apologies if there are threads about this elsewhere on the site but I don't often visit (usually only when I have a problem!).
Thanks,
Ecosse_Cross
Old May 9, 2009 | 12:25 PM
shaverj's Avatar
Default Re: Noisy clutch??
I'm no expert with the crossfire but from previous vehicle experience I would suggest its the release bearing failing...
Old May 9, 2009 | 01:06 PM
If this turned out to be the problem is it repairable (easily/cheaply) or would it mean a whole new clutch?
Thanks for the advice, will get it checked out.
waldig
Aug 24, 2015 10:40 PM
needfreetime
Aug 1, 2015 07:06 PM
UNDER PSI
Aug 1, 2015 02:11 AM
ricardo 53
Jul 21, 2015 07:49 AM
BlackCrossFire6spd
Aug 21, 2006 10:48 AM
