Forum's BAS/ESP solution
Old May 12, 2009 | 12:55 PM
cisa's Avatar
Exclamation Forum's BAS/ESP solution
Today I had a new Battery installed in my Crossfire. As I was driving to work from the Firestone Store (with my new Interstate MTP91 battery as recommended on the Forum), I noticed that the BAS/ESP light was on.
No panic, when I got to work I checked the forum and found that after a battery change you may need to reset the light. Easy, "with the car on turn the steering wheel all the way right, then all the way left. Turn car off and then restart." The BAS/ESP is now off. Another problem solved and a win for the folks on the Crossfire Forum!!!!!
Old May 12, 2009 | 07:29 PM
downwardspiral's Avatar
Default Re: Forum's BAS/ESP solution
The BAS/ESP light is off right?
Old May 12, 2009 | 07:48 PM
patpur's Avatar
Senior Member/Moderator
Glad it worked for you, I've been down that road with both my Crossfire and our Mercedes. The Mercedes needed a steering angle sensor......
Old May 12, 2009 | 07:55 PM
We've had issues with that light before. The dealer could never find the problem. It turns out that one slightly low tire can set it off even before setting of the TPS light.
Old Feb 13, 2010 | 05:39 PM
Larry Hitze's Avatar
I just put my Relay Control Module after a Tighed1 solder repair and the Me So Horny Mod and got this light. Thanks for the problem info and repair solution. I knew I'd read about it somewhere before. The light is out. Much Appreciated - Larry
xfClifford
27
Nov 10, 2015 10:08 PM
velociabstract
28
Oct 28, 2015 12:46 PM
Adrian_X
Jul 12, 2015 11:05 PM
2005 Ragtop
Jul 9, 2015 03:16 PM
Blackout317
Jul 7, 2015 08:38 PM
