Battery relocation...?
Old May 12, 2009 | 11:12 PM
Skyshadow's Avatar
Default Battery relocation...?
Has any member done this? If so, Can you help me out by telling me what supplies you used and how you went about it.
Old May 13, 2009 | 07:57 AM
spensley's Avatar
Default Re: Battery relocation...?
Talk to TVT, and look at their website - I think they moved there's to the trunk.
Old May 13, 2009 | 10:23 AM
faiz23's Avatar
honestly it is not that hard what so ever look at my gallery i did not relocate but i have an extra battery in the rear. I ran a new 1/0 gauge power and ground wire from the front to the back. I use kinetik side terminals to attach the wires for the front and back together. Both wires go down the passenger side and their is a nice opening on the back wall close to the gas tank for you to fish the wires through. I fit 2 1/0 gauge and i bet i could fit a couple more through the opening. Then i added a second ground in the rear to the stock grounding point on top of the pass wheel well.
make a battery tray tie down and hold it in place towards the back their is dead space by the tail lights. If you buy a new sealed battery you could slide it into the slot sitting long ways instead of normal position since the dead space is taller then it is wide. With sealed batteries like optima, kinetik, you can run them in any position.
i have not tried this but what i plan to do is remove my front battery which is kinetik 1800 and run only the kinetik 800 in the rear for weight reasons.
blackpepper
Oct 4, 2017 06:09 AM
Reliableron
Oct 17, 2015 10:19 PM
o55ie18
Oct 5, 2015 05:50 PM
rmcdaniel12
Sep 22, 2015 01:20 PM
Valk
Sep 17, 2015 11:43 AM
