headlight adjustment
Old Jul 2, 2009 | 01:14 PM
Default headlight adjustment
Do our headlights ever need to be adjusted and if so, does anyone know how and the specs.?
Old Jul 2, 2009 | 01:23 PM
Default Re: headlight adjustment
No need unless you have played around with the screws. What is going to move? Look in the shop manual for more info.
Old Jul 2, 2009 | 01:34 PM
maxcichon's Avatar
With the sharp cut-off lines on our cars, a great rule-of-thumb is to NEVER adjust them any higher than the bottom of the side rearview mirror on another car. Some say the "trim line". If you are behind some one and you are shining your low beams on that mirror- they are too high
Old Jul 2, 2009 | 01:38 PM
I'm removing mine to do a black out look and then reinstall. In the old days there was a process of having you car 10' from a wall and adjusting the 3' off the ground and the center of the beam 7' apart. I guess the same general rule applies. Sometimes I sure wish big trucks and SUVs had their beams adjusted a little lower.
n/
Old Jul 2, 2009 | 02:38 PM
///SilverSaphRT6's Avatar
I adjust mine in the Garage....just even out the cutoff lines about knee cap height.... 2ft for me.
Old Jul 2, 2009 | 03:43 PM
OKC-XFR's Avatar
Before you take them off, mark where they shine on the wall and where you parked. After re-installation, park in the same location and adjust them to the same spot on the wall.
smfrycruzr
Jul 17, 2023 05:33 PM
Franc Rauscher
May 9, 2016 12:04 PM
2005 Ragtop
Oct 3, 2015 03:01 PM
atdavis2
Sep 21, 2015 01:25 PM
RacerXofFL
Sep 15, 2015 05:00 PM
