Replacing the Fuel Filter
Old Jul 16, 2009 | 01:43 AM
Style's Avatar
Default Replacing the Fuel Filter
Ok so I want to replace the fuel filter on my XF. Not as simple as many of the cars I've had before so calling on the experience of everyone here...
Couple of questions:
  • http://homepage.mac.com/gregmeach/XFire/Xfire_Repair_14-FuelSys.pdf Note, this link explains the maintenance and repair procedure for anything associated with fuel on the XF. My question is this: Is it possible to release the pressure in the system without a DRB IIIT scan tool and is it possible to do it without throwing Diagnostic errors. Note that step seven of the procedure is this 7. One or more Diagnostic Trouble Codes may have been stored in PCM memory due to fuel pump fuse removal. The DRB IIIT scan tool must be used to erase a DTC
  • If it does throw errors how do I remove them without the scan tool?
  • Major dumb question...after instalation is there a 're-pressurising' procedure or is it just hook everything back up and the fuel pump does the rest?
  • And finally, is a generic filter (say a ryco z626) as good as OEM fuel filter. Should I stick with OEM here or would it make no difference.
Any advice would be greatly appriciated Thanks Heaps!
Old Jul 16, 2009 | 09:53 AM
former NXMX5's Avatar
Default Re: Replacing the Fuel Filter
changing the fuel filter does not require a DRB, nor does it throw error codes.
theres no repressuring procedure after the filter change. you may have to hold the key for a little longer to get it to start though.
ive always gotten OE replacement filters; couldnt find anything aftermarket the first time i did it, and i havent looked for one since. $100 once a year? its worth it.
Old Jul 17, 2009 | 04:27 AM
Style's Avatar
Thanks Rob, really appreciate your input. I'd really like to go OEM for the filter but it's like $250 for one here in Australia...dunno why. Cheapest I can find after market is $160 odd dollars for a ryco z626. Apparently Ryco have been making them for a year and a half now. Hope the quality is comparable....
Great to know that it doesn't throw error codes, that's the piece of mind I was hoping for.
Cheers
Josh
Old Jul 17, 2009 | 07:19 AM
LugNut's Avatar
I don't know about the shipping charges to Down-Under, but check out Rock Auto for aftermarket parts.
Auto Parts Fast at RockAuto
Old Jul 21, 2009 | 03:35 AM
blackroadster83's Avatar
Cool Re: Replacing the Fuel Filter
Were is the fuel filter located? I wanna change mine to
Old Jul 25, 2009 | 06:21 AM
Style's Avatar
Thanks mate that site's awesome!
Old Jul 27, 2009 | 09:20 AM
its just inboard of the right-rear wheel.
Old Jul 27, 2009 | 12:03 PM
caddyman3's Avatar
Just replaced mine last week. It was fairly simple with the exception of the lines being stuck on the filter. I had to wrestle with them for a while. Make sure you have some new hose clamps. You can release fuel pressure under the hood on the right front of the engine at the end of the fuel rail. Just unscrew the cap and press the relief...make sure you have some goggles on ha ha ha.
Old Aug 9, 2009 | 10:03 AM
Mattporter's Avatar
I have a 2004 crossfire and want to replace the fuel filter where is it? Ive been told in the tank and in the engine bay which is it?
Old Aug 11, 2009 | 08:29 AM
danimal's Avatar
Neither. If you follow the link in post #1, it will give you all the info you need. Here it is again for you to just click on:
http://homepage.mac.com/gregmeach/XF...14-FuelSys.pdf
Old May 30, 2020 | 08:47 AM
phil alvirez's Avatar
found this: https://www.slkworld.com/threads/r17...-change.31275/
for all that i see, it is the same for the crossfire
perhaps just the cover is a little different. otherwise seems the same.
in this video he shows exactly how to remove it:
PNA
Nov 12, 2020 04:44 PM
BrenLW
Aug 5, 2015 04:53 AM
Jul 29, 2015 06:13 PM
crymar
Jul 17, 2015 08:46 AM
