Headlight Switch
Old Jul 23, 2009 | 11:04 AM
CHS's Avatar
CHS
Default Headlight Switch
Does anyone know how to remove the headlight switch
Thanks ,
Wayne
Old Jul 23, 2009 | 11:51 AM
user 8202's Avatar
Banned
Default Re: Headlight Switch
1. Remove the fuse access panel found to the left of the switch at the side of the dash. You will see a black screw, upper right, remove it.
2. Under the steering wheel where it meets the dash you will see one exposed silver screw. Remove it and the trim piece it was holding in place can now be removed.
3. With the centre trim piece now removed, two additional screws to the left and right are now exposed. Remove them.
4. Looking under the dash you will find three or four additional screws that need to be removed. These screws can be found on the forward edge of the cover. Likewise, at the rear you will find two additional screws that only need loosening, not removed.
5. The under cover will now drop down by just pushing it back to allow the two rear screws (the ones you loosened earlier) to pass through a larger hole that when done, releases the entire cover. It will simply drop down in your hands.
6. The Headlight Switch drops down with the cover as it is attached by two small black screws. It will be obvious when looked at.
That's pretty much it. Release the four harnesses from the back and you have the switch in your hands.
7. Assembly is done in reverse.
Hope this helps.
Old Jul 23, 2009 | 11:57 AM
maxcichon's Avatar
SLK Home Page
Poke around in here! All kinds of useful stuff.
Old Jul 23, 2009 | 01:00 PM
CHS's Avatar
CHS
Thanks for the replys , I think I might have an issue with the switch . foglights just popped on and won't go back off without pulling the fuse .
Osusannah
Feb 12, 2024 01:49 PM
smfrycruzr
Jul 17, 2023 05:33 PM
Franc Rauscher
May 9, 2016 12:04 PM
Reliableron
Oct 17, 2015 10:19 PM
o55ie18
Oct 5, 2015 05:50 PM
