Automatic transmission fluid check tool length?
Old Jul 26, 2009 | 07:31 AM
LugNut's Avatar
Question Automatic transmission fluid check tool length?
Anyone already have one of the Miller Specialty Tools #8863A or B, or MB $140 15 21 AT fluid check tools?
If so, could you please measure the length for me? Thanks.
{Our ATs are MB's 722.6 's?}
P.S. I see a rebuilt AT on eBay for $100! Can't vouch for the seller in KY, but seems like a great deal if the correct trans. The auction number is 170361752551.
Old Jul 26, 2009 | 10:04 AM
MikeR's Avatar
Default Re: Automatic transmission fluid check tool length?
The Miller tool is 52" long, from the end of the handle to the tip of the dipstick. The black graduated measure portion is 3 1/4" long. The graduations are every 10mm from the TIP.
Old Jul 26, 2009 | 01:12 PM
LugNut's Avatar
Great, thanks! Hopefully I can find the correct one (I see others). I see that we are supposed to have the stick just-hit the bottom of the pan, then read up from there. Unlike "normal" cars that have fixed-length, factory-supplied dipsticks.
Old Jul 26, 2009 | 02:07 PM
32krazy!'s Avatar
when you insert the tool approx 8" will stick out of the tube. this is a multi tool fits many cars. thats why you insert it until you feel it just touch the pan and take the readings from the bottom
Old Jul 26, 2009 | 02:53 PM
billangiep's Avatar
There's an older thread where someone modified a zip tie..42 inches comes to mind from the top of the dip stick tube to ....?
Old Jul 28, 2009 | 08:42 AM
waldig's Avatar
Talking Re: Automatic transmission fluid check tool length?
THat was me, I used a big zip tie, white that was trimmed to fit in the pipe, measure up from the bottom and your done. No real money and easy to use.
BTW if you over fill the tranny it will pump out the excess anyway. Neat ??
Woody
Old Jul 31, 2009 | 10:10 PM
ChuckNorris's Avatar
Got this off Benz forum, other very helpful information about our trannies there.
Old Sep 10, 2009 | 01:04 PM
Crossfire451's Avatar
Is the full line at 5.5mm (in the picture) ? And, does this dip stick touch the bottom of the pan?
Old Sep 10, 2009 | 04:02 PM
The hot 80c full mark is between 5.5 and about 6.5 and dipstick should be inserted till it hits bottom of pan while in park with engine running.
Old Sep 10, 2009 | 06:14 PM
MikeR's Avatar
That pic is interesting. Mine has graduations every 10mm and no indicators for min/max.
Old Sep 15, 2009 | 07:09 PM
LugNut's Avatar
One of the tools on the way, off eBay for cheap. Love that eBay, most of the time.
Old Sep 15, 2009 | 09:24 PM
crossfire08's Avatar
where do you check it at?
thanks
Old Sep 15, 2009 | 10:25 PM
LugNut's Avatar
Right, rear of the engine -- filler tube with a locked cap. Need a replacement clip each time it is opened. Haven't done mine yet, but hopefully soon. BTW -- requires a special fluid, apparently. $$, no doubt.
Old Sep 15, 2009 | 10:43 PM
Sandgrounder's Avatar
Photo of the location would be realy nice.
Manual transmission fluid is ATF+4
Automatic transmission fluid is Shell 3403 ATF
Page 222 Owners Manual
Old Sep 16, 2009 | 07:02 AM
LugNut's Avatar
"Photo of the location would be realy nice."
If I remember to, I'll take and post some. Will be a while until, however.
"Automatic transmission fluid is Shell 3403 ATF"
I haven't really gone hunting for it yet. Found it? If so, where? WM having that particular fluid would be nice ...
Old Sep 16, 2009 | 01:45 PM
in the older days when dextron and type F (ford) fluids were kings, you could pick up a cheap shift kit and switch from dextron to type f and see a real differencein shift quality. just changing the fluid type made huge differences. this was attributed to the friction coefficient of the of the type f because of this history it makes me wonder about the differences in the shell TF and Mopar atf+4. has anybodyexperienced a difference after changing their fluid?
Old Sep 16, 2009 | 02:03 PM
tighed1's Avatar
More info and pictures here...
https://www.crossfireforum.org/forum...stick-cap.html
Old Sep 16, 2009 | 02:38 PM
LugNut's Avatar
Question Re: Automatic transmission fluid check tool length?
That thread says the Chrysler part number for the fluid is 5127382AA. OE Discount Parts shows it as $11.58 -- I'd guess that's per quart (!), but anyone know differently, e.g., gallon or liter?
Old Sep 16, 2009 | 10:07 PM
Originally Posted by tighed1
Thanks ,I will go digging this weekend to find the little bleader,sorry is it also the filler?
Old Sep 17, 2009 | 02:39 PM
Now there's a practical item for someone to manufacturer and sell (dipstick) .
