P0171
Old Jul 26, 2009 | 10:33 PM
caddyman3's Avatar
Default P0171
I got my first code and did a little research to the P0171 code and found little help. Engine running lean on bank 1...I changed my fuel filter and the fuel pressure is good (about 55-60). Air filters are good and I also looked at my MAF sensor which looked fine. My car is idling rough and upon acceleration is hesitates pretty bad sometimes. Does anyone have a clue to what may be causing this?
Old Jul 26, 2009 | 11:38 PM
GDC-SRT's Avatar
Default Re: P0171
https://www.crossfireforum.org/forum...st-leak-2.html
This link may help.
Sounds like you may have a vacuum leak.
Old Jul 27, 2009 | 05:10 PM
TruTaing's Avatar
Default Re: P0171
Hop over to the mbworld forums and check out how many instances of MAF issues threw the fuel trim codes. I had the same issue w/ my engine. replaced the MAF and all my codes went away. The MAF is very finicky Dont buy from ebay either, there is some vw knock off that will cause even more issues.
newaustinite
Jul 26, 2019 07:16 PM
jimmirehman
15
Sep 5, 2015 04:59 PM
cjfine
Mar 12, 2015 11:20 AM
Selbyl
Feb 4, 2014 09:31 AM
aphuntin
May 27, 2013 04:38 PM
