I just discovered Eurocharged!!
Old Jul 27, 2009 | 10:15 PM
samo59's Avatar
Default I just discovered Eurocharged!!
So I just discovered Eurocharged after seeing it on the bottom of some of your guy's posts. I have a question though. I am interested in getting the Cryogenic Air Intake, or two of them cuz i want to make a dual CAI. However, could someone tell me more about this? Does it work as cool as it sounds? Would it give me more HP gains than just a normal dual 3'' CAI like some of you guys have? Thanks!
-Sam
Old Jul 28, 2009 | 08:01 AM
ShinobiOfLegends's Avatar
Default Re: I just discovered Eurocharged!!
-Sam
are you a n/a or srt? if your a n/a, dont waste your money. I run C02 on my 3000GT. It works by cooling around your intake, fuel lines, intercooler, etc. But its erally only useful on motors making lots of heat, i.e, forced induction motors.
Old Jul 28, 2009 | 08:32 AM
ImportLabSRT's Avatar
CryO2 is a cooling mod and its self, Does NOT add HP. What is does is cool down the the components that air and or fuel travels thru. CO2 is not combustible and should not be ingested into the engine.
Old Jul 28, 2009 | 09:48 AM
Mimi05SRT6's Avatar
Correct, it doesn't give you more hp, but just gives back the hp you lost due to the heatsoak.
Old Jul 28, 2009 | 02:56 PM
samo59's Avatar
Ohh, i see. Interesting. I have an N/A Crossfire. So I shall stick to my custom CAI then. Thanks for the info guys!
-Sam
Old Jul 28, 2009 | 05:05 PM
Sam, you ever have questions for EuroCharged, Jake will take and answer all your questions. All those guys are super to work with, can't wait to take my next trip up to their shop...
Old Jul 28, 2009 | 05:51 PM
-Sam
Go for a tune with your CAI. These guys gave me 54 added HP(at the crank) with a tune, CAI, injectors and a slight Exhaust Mod.
Dyno proved it.
Also, they changed the parameters to better shift points. My car is amazing.
roadster with a stick
Old Jul 28, 2009 | 06:11 PM
ZAHANMA's Avatar
Time for you to get rid of that Code 3 Pulley and put on a Eurocharge 185mm pulley...feel the power (though not as cool as a turbo crossfire). hahaha.
...and get Eurocharged H/E also...
xfireohio
Jul 20, 2020 12:03 AM
UNDER PSI
Nov 1, 2015 09:39 PM
steps
Oct 13, 2015 06:18 PM
RacerXofFL
Sep 15, 2015 05:00 PM
rmcdaniel12
Aug 7, 2015 01:37 PM
