Subs in a convertible
Old Aug 6, 2009 | 02:17 AM
Fiatman's Avatar
Default Subs in a convertible
I've searched on this, but haven't found much definitive....is there anywhere else (such as beside the stock subs) that other subs could be put? Or are we pretty much relegated to a flat box in the trunk under the conv top bay? I realize mounting depth is a big problem with replacing the subs in back, and it not being an even semi-sealed box hurts that location as well....but has it been done?
It's a given that you have to separate-amp any subs beyond stock. After the door spears were capped and replaced and deck replaced, you can definitely hear when the stock amp runs out of juice and when those poor 6" subs run out of throw.
Old Aug 8, 2009 | 08:17 AM
cookieman's Avatar
Default Re: Subs in a convertible
Hi, check out my roadster install thread.The sub i used is a jl audio 13tw5 and only needs a 2.5 inch mounting depth.In my opinion, it is your only choice if you want something that will truly do the job.There just is not any room any where else to get the results i think you are looking for.
Old Oct 24, 2011 | 12:18 PM
2005cross-benz's Avatar
whats up man the truth is the drop top crossfire can bang and i meen really really bang if you sacrifice your trunk im pretty sure i have not only the loudest drop top xf but the clearest and best sounding and still can drop the top with no problem i have herts special car audio compontents in the doors amped at 1000 watt 1 channel memphis amp i have a jeson 7in flip out as the deck a 1500 watt mephis 2 channel amp pushing 2 pro comp orion 12in subs i have a huge capasitor and a 2nd battery in the trunk by kentic if u have any ?s hit me up bro
syfi
Mar 28, 2026 04:14 PM
Osusannah
Feb 12, 2024 01:49 PM
Darryl Camisa
Oct 7, 2015 07:10 AM
RacerXofFL
Sep 15, 2015 05:00 PM
