High Beams quit working
Old Aug 16, 2009 | 12:35 PM
TX_xfire's Avatar
Default High Beams quit working
I went to turn on my high beams and neither side is working. I checked the fuses first and they are ok. Could both of my bulbs gone out at the same time? Seems kind of unlikely, but still possible. Any other thoughts or things I should check before trying to replace the bulbs?
Old Aug 16, 2009 | 12:48 PM
robby363's Avatar
Default Re: High Beams quit working
Do they come on when you hold the swtch the opposite way like you would to flash them? If they do then it might be the switch. I had to have mine replaced wnen I first bought my car.
Old Aug 16, 2009 | 12:51 PM
TX_xfire's Avatar
No it never worked when I flashed them. Only when I pushed the switch forward. Now neither direction works.
Old Aug 16, 2009 | 12:54 PM
robby363's Avatar
I'd check the bulbs first but it sounds like it might be the switch.
Old Aug 16, 2009 | 01:04 PM
robby363's Avatar
these are the part# they replaced 5098519-AA SWITCH TURN SIG and 5098638-AA MOCULE HEADLAMP. I don't know the the price of the parts though it was done under warranty.
Old Aug 16, 2009 | 01:07 PM
TX_xfire's Avatar
Thanks for the info. Hopefully it is just the bulbs.
Old Aug 21, 2009 | 02:13 PM
The problem was .............?
Old Aug 21, 2009 | 02:35 PM
TX_xfire's Avatar
No solution yet. I haven't had the time to try changing the bulbs. From the post I have seen it sounds like a real pain in the ... I will let you know when I get it fixed.
Old Aug 21, 2009 | 03:09 PM
Stogey's Avatar
Have you tried testing the wiring with a voltmeter or test light ? Just curious !
Old Aug 21, 2009 | 03:15 PM
TX_xfire's Avatar
No I haven't really did anything yet. My inspection has to be renewed next month so I will have to fix it soon. Thanks for the idea.
wootto
U.K.
Aug 16, 2020 07:55 PM
Hoppy
Dec 7, 2018 07:36 AM
jgreen
106
Sep 18, 2017 11:46 PM
rocketrage
Oct 7, 2015 05:00 PM
ricardo 53
Jul 21, 2015 07:49 AM
