Brake Pad Disintegration!!! Another reason to change to Rotex Golds
Old Aug 19, 2009 | 04:31 PM
nate_man's Avatar
Default Brake Pad Disintegration!!! Another reason to change to Rotex Golds
I was installing the rotex golds last night as I put on my new wheels and when I pulled the stock pad on the drivers side the piston side of the pad just fell apart. See pics below.... Another benefit of putting on the Rotex Golds...
I am just glad this did not slip out while braking as I may have been into another car!!
Looks fine just sitting but voila it was not even holding together...
Old Aug 19, 2009 | 04:50 PM
MikeR's Avatar
Default Re: Brake Pad Disintegration!!! Another reason to change to Rotex Golds
I have never seen the pads rust apart from the plate before. Probably because you generally wear out the pads before they have been on long enough to do that. Guess I better to a check on the SSB pads just for good measure.
Old Aug 19, 2009 | 05:49 PM
nate_man's Avatar
Yeah and these were still about 55% remaining life! My car has only 20k and it is not an outside car.
A little disturbing to say the least...
Old Aug 19, 2009 | 11:33 PM
OKC-XFR's Avatar
It's funny that you posted this - I just did my pads (with Rotex Gold) and rotors a week ago mainly due to the dust and incessant squealing. When I took off the front passenger side caliper, the outboard pad stayed on the rotor just like you described:
Disturbing is the perfect word - if this would have separated during heavy braking, I probably would be needing a lot of brake and suspension parts...maybe even front end parts altered by the car in front of me.
The good thing about this is that I don't have to listen to the brakes squealing constantly any more! And I was able to show my wife that I wasn't crazy for changing out brake pads that "didn't need to be changed"! (She thinks I'm obsessed or something - go figure )
Old Aug 20, 2009 | 09:26 PM
nate_man's Avatar
Well I just put 150 on my ride today with the new RG's and not a problem. I am glad that I changes my stockers because the dust was unbearable not to mention them falling apart!
Thanks for sharing cuz I thought I was the only one. Others may need to do the RG change and may find the same problem! Surprised no one has had a failure yet!
BTW I found the best RG prices on: Rotex Gold Brake Pads: ImportPerformance.com
Only 56 beans! Not bad for $90 pads.
PNA
Nov 12, 2020 04:44 PM
Kodebuster
Nov 5, 2020 04:06 PM
tom2112
Dec 1, 2015 09:02 AM
Jul 29, 2015 06:13 PM
Romio
Jul 24, 2015 07:04 AM
