Thermal Coatings and Dispersants
Old Oct 5, 2009 | 08:22 PM
TVT_DESIGN
Guest
Posts: n/a
Default Thermal Coatings and Dispersants
With the advances in engine coating these days, I decided to take a gamble and invest in one of the leading companies dealing with engine coatings.
Tech Line Coatings | Automotive ( Hi-Performance ) Coatings
They sell everything you could possibly imagine, and a lot of stuff you couldn't, to coat all parts of your engine, brakes, exhaust, etc.
I applied some of the Thermal Dispersant coating to the intake manifold on the outside. We covered both the top and bottom to maximize the benefits.
TLTD THERMAL DISPERSANT
  • Rapidly disperses heat away from a coated component.
  • More evenly distributes heat over a coated surface.
  • Aids in cooling heat sensitive parts.
  • Excellent for intake manifolds, brake components, oil pans etc.
  • Very good chemical and corrosion resistance.
  • Black in color.
  • Cosmetically appealing.
  • Requires baking. Cures at 300f minimum. Must be oven baked
First impressions are that this is the best stuff I've used on an engine ever. With in 15 mins the manifold went from a scorching 300 deg, to a cooling 68 degree. Unbelievabe.
As many of you know these engines retain heat for what seems like hours and hours. I can see this being extremely effective during drag racing and everyday driving. Imagine not having to worry about heat soak between runs!
The SC cars can benefit from this as well by coating the SC and intercooler.
I'll be applying this caoting to the tops of the valve covers, oil pan, intake tubing and water pump housing.
I'll be using the oil shedding thermal barrier to the inside of the valve covers and inside of oil pan. I also picked up CBC2 for the cylinder head combustion chambers.
I'm very happy with the results so far and only expect them to get better from here.
Old Oct 5, 2009 | 09:03 PM
32krazy!'s Avatar
Default Re: Thermal Coatings and Dispersants
i cant seem to find the product your using on the website
Old Oct 5, 2009 | 10:01 PM
TVT_DESIGN
Guest
Posts: n/a
It's under internal engine coatings.
Old Oct 6, 2009 | 05:31 PM
32krazy!'s Avatar
2 questions. which would be best for coating my stainless steel tubes in my air intake system and how bad is the smell while cooking? i dont have a spare oven in the garage and dont want to fumigate the house!
Old Oct 6, 2009 | 05:38 PM
MikeR's Avatar
How do I get my engine in the oven??
Old Oct 6, 2009 | 07:46 PM
Jeep2Xfire's Avatar
Heads separate from the block?? Block minus the oil pan isn't to terribly tall right?? Just have to take the racks out. Make sure the wife is on a trip to Vegas beforehand though. Don't want her seeing you "Cook" your engine...
Old Oct 6, 2009 | 07:59 PM
black05's Avatar
i agree. this is unbelievable. please explain the conditions where the part went from 300 deg to 68 deg. certainly wasn't in the oven baking. wasn't on the engine either unless the ambient air temp was 68 deg and the engine was cooled to ambient air temp. your missing part of the story.
Old Oct 6, 2009 | 11:37 PM
TVT_DESIGN
Guest
Posts: n/a
It came from the oven at 300 and cooled off to 68 which was ambient. Not much else to tell.
That is extremely impressive for these manifolds as the uncoated pieces were still warm to the touch after this time.
There is almost no smell associated with the baking. Only tools needed are a sand blaster, a detail spray gun, and an oven.
waldig
Sep 17, 2015 10:35 AM
RacerXofFL
Sep 15, 2015 05:00 PM
maxcichon
Sep 4, 2015 12:50 PM
velociabstract
Aug 28, 2015 11:20 PM
bbsrt6
Aug 27, 2015 07:07 PM
