Install
Old Oct 10, 2009 | 12:50 PM
svtcobra's Avatar
Banned
Default Install
Is it hard to install the stage 2 ported manifold with injectors and 74 mm throttle body yourself cause Ive ordered these parts but I'm running low on cash and a local shop wants to charge me 400 to install
Old Oct 10, 2009 | 03:20 PM
newCrossfire's Avatar
Default Re: Install
i wouldnt think itd be to hard. the injectors were easy and ive heard the throttlebody is easy to swap out. just tag all you connectors so you remember where they go. it also helps to take pictures as you go. You may also want to find the torque specs for the manifold bolts.
Old Oct 10, 2009 | 05:01 PM
TVT_DESIGN
Guest
Posts: n/a
Default Re: Install
That's a little on the high side, but it depends on the labor rate. It will take about 2.5-3 hrs. It is extremely straight forward. I have no problems with walking you through it over the phone, so don't hesitate to call.
Old Oct 10, 2009 | 05:26 PM
svtcobra's Avatar
Banned
Default Re: Install
R u Anthony ???
syfi
Mar 28, 2026 04:14 PM
TerryR
Dec 13, 2019 03:27 PM
UNDER PSI
Nov 1, 2015 09:39 PM
2005 Ragtop
Oct 3, 2015 03:01 PM
ozkancab
Sep 25, 2015 10:55 AM
