vrp throttle body
Old Oct 21, 2009 | 12:00 PM
welder7018's Avatar
Default vrp throttle body
VRP 80mm Throttle Body Kit
$1,925.00
Our 80mm Throttle Body upgrade kit is a direct bolt on for all M113 Kompressor engines. It increases throttle body size an additional 6mm over stock which helps to reduce the bottleneck in intake airflow. The car's part throttle response is greatly improved as is the top end pulling power. This is A MUST for modified cars, but also offers significant gains on stock vehicles. We have seen as much as 25-30rwhp. We include everything needed to install it in your vehicle: AMG 80mm Throttle body, AMG 80mm Supercharger inlet, 80mm Y-pipe, throttle body gasket, Supercharger inlet gasket and 4 stainless bolts.
  • Shipping Weight: 11lbs
  • 10 Units in Stock
so i was wondering if this would work on the na....i want a 74mm but cant seem to find one
Old Oct 21, 2009 | 12:23 PM
ZAHANMA's Avatar
Default Re: vrp throttle body
I do not think this will work for the SRT-6 or the N/A (M112 engine) this is an upgrade to the 55 V8 (M113) engine I believe.
You might want to contact TVTDesign about a 74mm throttle body for your N/A he might have them or be able to get one for you.
Old Oct 21, 2009 | 05:07 PM
downwardspiral's Avatar
don't waste your money.. the TB's effect is definately not worth that much, and 80mm is definately overkill. I found a total of 3 that cost just under $200 at salvage yards. I got one from Weber Brothers in PA. Their phone number is 1(800)222-2528. Just tell them that you are looking for a throttle body, mercedes part #113 141 01 25. If they ask what it came off of, tell them it came from a 2003 S-Class, but came on other cars with v8's. I think they had 4 when I called, I'd call now but they close at 5 and its 5:17.
Old Oct 22, 2009 | 01:31 AM
welder7018's Avatar
thanks guys ...when do u feel the response of the car actually
syfi
Mar 28, 2026 04:14 PM
cjw
Oct 26, 2015 10:26 PM
2005 Ragtop
Oct 3, 2015 03:01 PM
cjw
Sep 27, 2015 10:22 AM
atdavis2
Sep 21, 2015 01:25 PM
