Hood Liner
Old Oct 29, 2009 | 06:49 PM
cassidyrj1's Avatar
Default Hood Liner
How important is the hood liner? If you took it off would you be able to hear the supercharger better? But also if you took it off would the hood deform from the heat or the paint melt?
Old Oct 29, 2009 | 06:57 PM
+fireamx's Avatar
Default Re: Hood Liner
Since the Base car never came with a liner from the factory, I don't think you would have any problems.
Old Oct 29, 2009 | 07:00 PM
tighed1's Avatar
I haven't seen any ill effects in the area of the hole that I have in my hood liner. (I'm missing an area of hood liner where an experiment went wrong while I was trying to figure out how to get the supercharger to be on all of the time).
So I don't think any damage will occur if I take the remaining hood liner off. Actually it might even look better!
32krazy!'s Avatar
remember that the base model doesnt anywere near the amount of heat in the engine compartment that the srt-6 does. i do believe however woody removed his liner without issues
Old Oct 29, 2009 | 07:04 PM
32krazy!'s Avatar
how about glueing some polished aluminium to the underside so it reflects the motor!!
Old Oct 29, 2009 | 07:07 PM
+fireamx's Avatar
The hood liner is for "SOUND DEADENING" purposes. I doubt if it offers much heat insulation.
cassidyrj1's Avatar
I thought about doing that but using a mirror film instead of aluminium. If it looks like crap I can peel it off or just put the hood liner back on. I will do it on saturday and will post some pics.
Old Oct 29, 2009 | 07:16 PM
mrphotoman's Avatar
lol i want to hear more about this experiment!
Old Oct 29, 2009 | 07:34 PM
cassidyrj1's Avatar
Tighed 1 do we have eltronic clutches on the supercharger? Also the supercharge turns on at a certian rpm. So some how there must be a regulator to tell the supercharger to turn on when the car gets to that certian rpm. So what would happen if you just hooked the power source for the supercharge to a power source that is always on. Then the supercharger would be on at all times. Would this work or does it have nothing to do with what i just said.
Old Oct 29, 2009 | 09:02 PM
spensley's Avatar
I believe TVT removed their liner for better heat dissipation. I don't think they've had any issues.
Old Oct 29, 2009 | 10:21 PM
SRTGuy's Avatar
Then the ECU wouldn't know when the supercharger was on or not. That said, I'm not sure what input signal the ECU uses for fuel maps(SC on 0/1) or manifold pressure or RPM etc. It might have no effect, but I can almost guarantee someone already tried it on here.
Old Oct 29, 2009 | 10:24 PM
cassidyrj1's Avatar
What if you just put a full time power source to it and still kept the regular wires. Then wouldn't the power go back through the stock wires and then the ecu would be tricked into thinking it was on.
Old Oct 30, 2009 | 12:02 AM
tighed1's Avatar
Tighed 1 do we have eltronic clutches on the supercharger? Also the supercharge turns on at a certian rpm. So some how there must be a regulator to tell the supercharr to geturn on when the car gets to that certian rpm. So what would happen if you just hooked the power source for the supercharge to a power source that is always on. Then the supercharger would be on at all times. Would this work or does it have nothing to do with what i just said.
Trust me you don't wanta go there. The car will run slower that an N/A car. I think Woody tried this also. It doesn't work. The car knows.
Old Oct 30, 2009 | 12:11 AM
+fireamx's Avatar
Well, after taking a closer look at my hood liner (mine's removed) I found a small spot chewed away by a mouse (don't ask) Anyway, I noticed the aluminum foil material inside, so it does act as a heat insulator as well. My bad.
I guess if I had one of those SRT "toaster ovens" under my hood, maybe I would be a little concerned. Or I'd open up my hood scoop to let the cool air in and not worry about it.
Old Oct 30, 2009 | 12:19 AM
tighed1's Avatar
Ok here's the deal. Once the above didn't work (hooking the SC up to constant 12v) I decided to try to mechanically keep the SC engaged.
I removed the SC pulley, cut pieces of bike inner tube and placed them in between the SC and the pulley so that the gap was eliminated and the SC would always be connected to the pulley.
Sure enough it worked! Boost was instant. No waiting till 1300 RPM or so. Till I put some RPM's behind it. Then Bam! Due to centrifugal force the inner tube was forced out of the gap and it "exploded". That's what removed a portion of my hood liner.
Hey! No laughin' out loud! I wuz doing it for all of us!
I'll try to post a pic later.
Old Oct 30, 2009 | 06:18 AM
waldig's Avatar
As part of my cooling efforts to allow full throttle operation for an extended autocross run AND the cool down after it, I did many changes such as:
Developed the super cooler heat exchanger
Designed a 180 thermostat
Removed the heat blanket
Added hood openings for MUCH better cooling
Opened the grill vent to allow better airflow
Separated the IC and radiator fluids
Added heat shield to the passenger exhaust manifold
These have been successful and I started to do the design of a fuel controller that I have not touched for weeks. I am into a big house construction project that the rain keeps delaying but I will return.
Woody
Old Oct 30, 2009 | 09:28 AM
mrphotoman's Avatar
lol nothing wrong with thinking outside the box that is funny as hell though!
you could always jb weld your pulley so the supercharger stays on
Old Oct 30, 2009 | 10:26 AM
LantanaTX's Avatar
Could you have run a wire to the clutch that was always on with the key? I have heard that a couple of people who have added the factory supercharger to na cars had to wire this way and the supercharger is always on. By the way, I removed my liner because there was some slight rubbing on my nice V8 engine cover. Without the liner I have no clearance problem.
Old Oct 30, 2009 | 10:52 AM
cassidyrj1's Avatar
Show off.
Old Oct 30, 2009 | 11:18 AM
distantpulse's Avatar
I took mine off without any issues yet......
