HELP! Water in trunk
Old Nov 8, 2009 | 11:07 AM
FUBU's Avatar
Default HELP! Water in trunk
Well, it is not pouring in. I just felt a bit of moisture and thought I wanted to prevent further problems.
Anyone experienced the same?
moisture / water building in trunk, close to the backwall, rear seats.
Easy repair? Parts?
/ Phil
Old Nov 8, 2009 | 01:52 PM
32krazy!'s Avatar
Default Re: HELP! Water in trunk
on my 32 there are 2 small drains near the bulkhead at the front of the trunk in the channels. not sure if you have them or not but on mine they can become clogged and let water drain into the trunk
Old Nov 8, 2009 | 03:29 PM
FUBU's Avatar
Thanks for answering, well, it is a complete different car. or?
"2 small drains near the bulkhead" where? :P
Old Nov 8, 2009 | 04:19 PM
32krazy!'s Avatar
this thread might help
Drains, front and rear - Benzworld.org - Mercedes-Benz Discussion Forum
Old Nov 8, 2009 | 04:38 PM
MikeR's Avatar
There is a body control unit back there too.... find the problem and fix it before it floods and causes you headaches. I dont recall which unit it is..... just remember reading some time back on here about it...
Old Nov 8, 2009 | 06:41 PM
cassidyrj1's Avatar
I had this problem. If you take the entire trunk apart and take out those foam inserts I had a puddle of water under there. I took my spoiler off and but some silicone under there and checked those rubber gasket things up near the hinges. It fixed the problem.
Old Nov 8, 2009 | 07:06 PM
FUBU's Avatar
See pic for problem areas that were a bit moist. I could see that the "thingie" that you use to take of the wheel with. wheel cross? were slightly rusty... evidence of water...
Old Nov 8, 2009 | 07:07 PM
FUBU's Avatar
So you think the rear spoiler is the trouble maker? I thought it was from underneath the car. Like the wall/panel between the seat and trunk..
Old Nov 8, 2009 | 08:23 PM
cassidyrj1's Avatar
Strange this is a guess but maybe your drain in the gas cap area is pluged and the gas tube is loose. If that is the case then it might be dripping down the gas pipe to the gas tank which is right behind that carpet. Try poring some water where you put your gas there is a little hole that should drain the water out. The problem I had was when i would open my trunk water would come out of the panels on the trunk lid so thats why I put silicone under my wing. Did you check your headliner to see if there were signs of leaking.
Old Nov 9, 2009 | 02:02 AM
FUBU's Avatar
As far as I can see no evidence of water leakage from the trunk rubber seal. I will check wing and gas tank later on this evening. What control body unit is mentioned earlier?
Old Nov 16, 2009 | 02:24 PM
FUBU's Avatar
Hi everyone. I have found the origin of the troublesome leakage. Firstly the glued back windows had a slight leak but now sorted after I went to a window repair shop. They helped me on the spot without charging. Secondly I found leakage from the trunk. It is wherefrom the electric cables goes from the trunk into the car the leakage starts. Those rubber seals were not tight enough. I aligned them better and used my silicongun aswell. I emptied the trunk Of all interior and found a puddle of water. The car is now in a dry garage drying. Hopefully the silicon will make the trick.
Old Nov 16, 2009 | 03:10 PM
MikeR's Avatar
Glad to hear that you found the leaks and that you reported back. Hope everything dries out good and no more problems for you.
Old Nov 16, 2009 | 04:37 PM
You mean the rear side window seal and the rubber boot, top left corner of hatch, that covers the plate light and air/vauum lines where the two sources of leaks?
Old Nov 30, 2009 | 12:00 PM
Hey, Guys...
My car is a Roadster and I had latch problems (see the crazy thread in "Roadsters").
Anyway, when I took the trim piece off the bottom of the hatch/trunk lid, I found streaks in the dust in there, indicating water was getting pas the seals around where the spoiler is mounted. I also have a LOT of corrosion on the bracket that holds the spoiler motor/gears/sensors. It has obviously been getting wet, probably when the car is being washed, as it's almost never been out in the rain (until this last Dragon).
The corrosion makes it clear that this has been going on for some time!
Not sure what I'll do about it, but thought I'd post something. I am not familiar enough with Coupes to know how similar things are in the mounting of the spoiler and the trim pieces, etc.
Osusannah
Feb 12, 2024 01:49 PM
RamblinShamblin
Aug 12, 2017 10:55 PM
rmcdaniel12
Sep 22, 2015 01:20 PM
cppeabody
Sep 15, 2015 08:43 AM
williammt
Sep 6, 2015 11:23 AM
