stock airbox>C320 Airbox>C350 AIRBOX!!!
Old Nov 17, 2009 | 11:57 PM
TVT_DESIGN
Guest
Posts: n/a
Default stock airbox<C320 Airbox<C350 AIRBOX!!!
The C350 airbox is a direct upgrade to the current C320 airbox. This airbox is on all M272 engines. It offers 3.5" inlets, a Y-pipe intake design, and less of a chance of heat soak due to the air routing. Filters are the same as the C320.
Old Nov 18, 2009 | 12:34 AM
Kit Fox's Avatar
Default Re: stock airbox>C320 Airbox>C350 AIRBOX!!!
Semantics but I think you got your less than and greater than signs messed up.
Old Nov 18, 2009 | 01:11 AM
TVT_DESIGN
Guest
Posts: n/a
That was always my weak point.
Old Nov 18, 2009 | 01:24 AM
Voyager's Avatar
those signs can get so dang confusing! I always have to think back to a pacman eating the smaller weaker thing haha
Old Nov 18, 2009 | 02:04 AM
GDrag's Avatar
Does it sound any different then the stock? How would you compare it to a single CAI?
I might be interested!
Old Nov 18, 2009 | 01:40 PM
goodgenes79's Avatar
Thanks TVT for all the experimentation and finding cost effective upgrades that make our toys just a little bit better. Not all of us need or can afford the full on, blowout, $800-1200 upgrades; it's great to find those mods that satisfy our disease and our wallet.
Old Nov 18, 2009 | 03:24 PM
No Warning Shot's Avatar
Seems sort of odd that it fits, the oil fill cap is on the opposite side. What does the little window in the middle show?
Old Nov 18, 2009 | 05:28 PM
TVT_DESIGN
Guest
Posts: n/a
Just the airbox itself fits, not the front cover, they are seperate pieces. That thing in the middle is where the new cars keep their ECU!
We have not run the car with it on, but the flow is designed like a Y-pipe. I'll snap some pics tomorrow of the back.
Old Nov 18, 2009 | 07:53 PM
Nice. You'd think all that heat on the top of the motor would be hell on a computer.
Old Nov 18, 2009 | 08:11 PM
Bladecutter's Avatar
Well, it kind of makes sense to mount it right on top of the engine.
That saves on running all the sensor wires from their locations on the engines all the way to either the left or the right fender well, and then back.
There probably is one nice, simple set of wires that run from the firewall to the ECU, and that's just about all you need to pull in order to pull the engine out, and swap in a new one, aside from fuel and coolant lines, of course.
BC.
Old Nov 18, 2009 | 09:01 PM
TVT_DESIGN
Guest
Posts: n/a
Been like that on the V12TT motors since '03.
Old Nov 18, 2009 | 09:58 PM
BC.
Interesting, but makes sense.
Old Nov 18, 2009 | 11:19 PM
Infinite's Avatar
I was contemplating just picking up a 3.5 m272
I found one for a deal, complete with harness and ecu, and its not a di motor.
dohc 4 valve > sohc 3 valve
Old Nov 19, 2009 | 12:42 AM
ProjectMayhem's Avatar
Don't for get the VTEC YO!
But seriously it has a VVT as well. so DOHC+4valves+VVT> sohc +3valves. The 3.5 was the next gen version of the m112 so its not surprising it was a better motor... here is a wild question would the 3.5 cyclider heads fit on 3.2 that would be sweet.
Old Nov 19, 2009 | 01:04 AM
Infinite's Avatar
well the m272 is based off of the m112 block
the problem is I have a 6spd and it looks like it uses the srt crank pattern.
but that fix is 1 phone call away.
usprb1976
Apr 4, 2024 04:57 PM
TerryR
Dec 13, 2019 03:27 PM
rmcdaniel12
Nov 4, 2015 04:08 PM
2005 Ragtop
Oct 3, 2015 03:01 PM
Sep 28, 2015 07:40 PM
