Sparkplugs
Old Nov 20, 2009 | 11:47 AM
RFC's Avatar
RFC
Question Sparkplugs
I Have A 05 Crossfire With 51,000 Miles And I Need To Change My Plugs What Kind Of Plugs Do U Recommend Me Buying To Get More Horsepower Or Should I Buy The Same Plugs It Has From The Dealer Can Someone Give Me Some Advice
Old Nov 20, 2009 | 12:11 PM
spensley's Avatar
Default Re: Sparkplugs
I suggest buying the plugs & wires which TVT & Needswings sell.
See their websites, and search this forum for information.
It's an easy DIY.
Old Nov 24, 2009 | 02:20 PM
RFC's Avatar
RFC
Thumbs up Re: Sparkplugs
Thank u that info was very helpful
Old Dec 26, 2009 | 01:25 PM
XF-LV's Avatar
Seeing good reports from the new E3 spark plugs.
I haven't used them myself but I am looking at upgrading on the next service.
I don't want to steer you wrong so is anyone up on these plugs?
Old Dec 26, 2009 | 03:20 PM
Crossfire451's Avatar
It may sound silly, but I replaced a plug in a chain saw with a E3 plug and it made a HUGE difference in how the saw started, ran and performed. I am planning on using them in the future.
Old Dec 26, 2009 | 05:24 PM
ShinobiOfLegends's Avatar
i think you are the only 2 actual people that like them. everyone that i know (including myself) that has used them or other multi-tip plugs have had nothing but complaints. the problem with them is that the 2 extra tips obscure the spark and prevent it the plug from being degreed properly.
Old Dec 26, 2009 | 09:24 PM
I understand what your saying, the other structures around the center electrode may interfere with the flame "kernel", In my saw's case it may be just the fact of a new plug made it run better. In my haste to post I might have overstated the plug's benefits. Several companies make special washers for plug degreeing. I've always read that ultimately the gap of the plug should face out into the cylinder or towards the intake valve to take advantage of the swirl affect around the intake valves
Old Dec 26, 2009 | 10:07 PM
I have an old snap-on plug tester and cleaner that, along with my multimeter, I used to test several plugs and the validity of the manufacturer's claims earlier this year to write a thermodynamics and electrical conductivity paper. it was quite lengthy and I can do another series of tests for everyone if they provide my with the plugs. I will charge the plugs with a battery of tests: conductivity, heat dissapation, dynamic resistance, static resistance, spark distribution, and spark output, as well as anything unique someone wants to know, as those were the criteria I used in my paper.
majority of the people that make the claim about plugs having "drastic" improvements are those that do have worn plugs and replace them with new ones.
typically you index the plug so that the gap is facing the intake valve or the space between the intake valves (like us). washers are generally not required because the manufacturer provides you with a range of torque specs, i.e. 11 to 15 ft/lbs, for indexing purposes. you are correct about this aiding in the swirl effect and it is also to prevent plug-to-piston contact in nitrous-fed, F/I, and high c/r vehicles.
majkls xfire
Oct 11, 2019 10:22 AM
HelotesKris
Oct 8, 2017 05:39 PM
turbobuckeye
Sep 11, 2009 10:32 AM
shreker
Jan 28, 2009 08:56 PM
crossfiretech
Sep 6, 2003 09:08 PM
