Adding the SRT6 SC to a limited 3.2L?
Old Nov 24, 2009 | 05:24 PM
CrossfireCliff's Avatar
Default Adding the SRT6 SC to a limited 3.2L?
I've searched the forum but found nothing. Can we add the stock Supercharger from an SRT6 to the limiteds 3.2L engine? if so, what mods are required and how tuff is it to do???
Old Nov 24, 2009 | 05:27 PM
bmorgan's Avatar
Default Re: Adding the SRT6 SC to a limited 3.2L?
The internals are not strong enough to handle the SC. It would be fun for a couple of passes down the track though.
Old Nov 24, 2009 | 05:29 PM
rcompart's Avatar
Couple people have tried, nobody has done it successfully without either blowing up their motor or going a different route. The compression ratio is too high on the NA motor and the SC makes too much boost so these two things you will need to overcome along with getting the right amount of fuel into the mix with the added air.
There is a guy doing a rotrex SC upgrade that looks about as promising as anything. Check out the thread here.
darnit! i was so hopeing cause there is an OEM sc on eBay for 399.99 right now
Old Nov 24, 2009 | 05:31 PM
rcompart's Avatar
Or a VERY short run up to 3500RPM.
Old Nov 24, 2009 | 05:34 PM
rcompart's Avatar
You'll need a lot more than just that. You'd need the upper plenums, the intake snout, a new front engine timing cover and the list goes on. The supercharger would be the cheapest part of the build.
Old Nov 24, 2009 | 06:16 PM
VERDICT IS................... Good Idea Scratched!
Old Nov 24, 2009 | 06:24 PM
smart man....there are other mods you can do....check out our vendors on here...
Old Nov 24, 2009 | 06:34 PM
ZAHANMA's Avatar
do you have a link?
Old Nov 24, 2009 | 06:47 PM
robby363's Avatar
Supercharger for Crossfire SRT6:eBay Motors (item 250536288140 end time Nov-30-09 23:47:23 PST)
Originally Posted by ZAHANMA
do you have a link?
Old Nov 24, 2009 | 07:11 PM
A quick search using "Supercharger na" found four pages and the first page had at least two threads that addressed this issue.
The answer always ends up "if you want a supercharged crossfire buy an SRT-6".
Old Nov 25, 2009 | 02:39 AM
Infinite's Avatar
there are more ways than a supercharger.
but yes, you could use the stock supercharger, youd have to have a custom pulley made so the blower made less pressure, fueling, etc.
the stock bottom ends are plenty strong WITH PROPER TUNING to make power.
I've boosted numerous 13:1 motors that have made 400whp and are still running (itr motors, etc)
Kodebuster
Nov 5, 2020 04:06 PM
rmcdaniel12
Sep 26, 2016 05:37 PM
gp1200x
Dec 6, 2015 12:59 PM
Jul 29, 2015 06:13 PM
Ralph289
Jul 26, 2015 12:52 PM
