Thumping Noise?
Old Nov 28, 2009 | 04:58 PM
arielfreed's Avatar
Angry Thumping Noise?
I currently have taken my car in 8 times for a thumping noise in the rear of the vehicle. It happens at a stop light with car in drive that it makes this noise (sounds like in trunk) and is so loud and can move the vehicle that sometimes feels like someone hit you from behind as the entire car moves. They changed the sway bar, said it was the differiential and took out the actuator power doors and now they are changing out something with the emissions but it still makes this noise. Makes it with both a cold engine as well as running for a while. Has anyone had this problem? HELP.
Old Nov 28, 2009 | 05:08 PM
robby363's Avatar
Default Re: Thumping Noise?
Does it happen when you accelerate or even when it's not moving?
Old Nov 28, 2009 | 05:09 PM
MikeR's Avatar
It sort of sounds like the carrier bearing on the drive shaft. I dont know that that would feel like you were getting hit though. It could make the thumping if worn bad enough. I lost a couple of U joints on my F250 due to a bad carrier bearing and it made a thumping when it got bad.
Old Nov 28, 2009 | 05:10 PM
bmorgan's Avatar
It alsmost sounds like differential pin failure. Check this out: https://www.crossfireforum.org/forum...n-failure.html
Old Nov 28, 2009 | 05:13 PM
MikeR's Avatar
eeeeeek! I forgot about that picture..... That would certainly fit your symptoms....
Old Nov 28, 2009 | 05:24 PM
bmorgan's Avatar
Yep.... could easily explain the feeling of getting hit from behind.
Old Nov 29, 2009 | 07:47 AM
arielfreed's Avatar
I only hear it when the car is not moving but is in Drive
Old Nov 29, 2009 | 07:54 AM
arielfreed's Avatar
Thank you for the info, I will have them check this out - did yours makes the sound only when you were at a stop?
Old Nov 29, 2009 | 08:15 AM
waldig's Avatar
Talking Re: Thumping Noise?
Old guys get to say odd things and they are expected..........Here goes.
Occures when sitting still - probably not the rear. But noise is in the rear.
Id give a good look at the fuel pressure regulator, vent line, and associated hoses. Thinking the fuel is sloshing, there is a pressure controller in the rear and your sitting still otherwise.
All located under the passenger seat area under a large plastic shield in the same area. Let me know, Woody ta da
OH yea, fuel tank baffel (s) ??? behind your seats
ty_ty37
Jun 27, 2024 10:42 AM
2005 Ragtop
Oct 3, 2015 03:01 PM
Oct 1, 2015 01:42 AM
pop49
Sep 30, 2015 11:14 AM
RacerXofFL
Sep 15, 2015 05:00 PM
