e500 or sl55 intake system
Old Nov 29, 2009 | 05:46 PM
kevinzarif's Avatar
Default e500 or sl55 intake system
what intake system can u put on the limited crossfire is it a sl55 or a e500
Old Nov 29, 2009 | 06:39 PM
32krazy!'s Avatar
Default Re: e500 or sl55 intake system
the e500 is most likley the setup you are looking for. the sl55 setup is dual airboxes the go on the the sides of the s/c. the e 500 has a cover over the center of the engine. i believe tvt has what you are looking for
Old Nov 29, 2009 | 07:14 PM
TVT_DESIGN
Guest
Posts: n/a
The best fits are the C320 and c350 intakes. They use the same filters as all the V8 boxes, but fit the 6 cylinder mounting points. The C350 box will flow much better then the C320 box.
Old Nov 29, 2009 | 07:20 PM
32krazy!'s Avatar
see i told you!!
Old Nov 29, 2009 | 08:37 PM
kevinzarif's Avatar
ok ill take you up on that, i put the sl500 intake on it and it was just to big so i think ill go with c class intake thanks
Old Nov 29, 2009 | 08:58 PM
32krazy!'s Avatar
now if you have a sl55 y splitter i can use it!
TerryR
Dec 13, 2019 03:27 PM
Oct 1, 2015 01:42 AM
Sep 28, 2015 07:40 PM
Dgiomatch1
Sep 20, 2015 01:05 AM
RacerXofFL
Sep 15, 2015 05:00 PM
