Door and Window Seal Protectant
Old Feb 11, 2004 | 02:23 PM
X-fired's Avatar
Default Door and Window Seal Protectant
What do you folks suggest for keeping the foam rubber door seals supple and squeak-free?
Old Feb 25, 2004 | 03:11 PM
Rob M's Avatar
Default
i just purchased my xf so i haven't treated the rubber yet. but i used to own a '95 corvette and used gm's dielectric grease to lubricate the seals. it worked pretty well though it can be a little messy. you can just put alittle on a towel, diaper, etc. and rub it on. the corvette had very soft rubber to minimize leakage into the targa top and doors and it was extremely prone to cracking. as a matter of fact, i was fortunate to get all mine replaced just before the warranty expired just a week after i purchased it used. the rubber can be quite expensive. i'm not sure how the xf's seals will last. i haven't read that far into the manual yet to see if there are any recommendations. so, i will eventually try the grease on the xf. hopefully, others will chime in here and can help determine whether my recommendation makes sense for the xf.
Old Feb 29, 2004 | 12:43 AM
jamespsnl's Avatar
Default Dielectric grease
Is this a silicone paste? James in St. Louis.
Old Feb 29, 2004 | 07:23 PM
Jamikest's Avatar
Default
Chrysler does have a weatherstrip lube available... It is not a standard car care product though.. It comes in a small (1 oz?) applicator bottle. We use this at my dealership on convertible top weatherstrips. Very effective in promoting a better seal against glass or painted sheet metal.
Old Feb 29, 2004 | 08:45 PM
Rob M's Avatar
Default Re: Dielectric grease
Not sure what's in it. It looks clear and has the consistency of vaseline petroleum jelly. But the 2 oz. jar it comes in doesn't list its content. It's used primarily to prevent corrosion to electrical terminals.
Since Chrysler makes a weatherstrip lubricant, I will see if I can get some from my dealership. Jamikest, thanks for the info.
Nexxus
May 8, 2016 04:43 PM
Mackel
Oct 16, 2015 09:03 AM
nataliefs
Oct 5, 2015 01:03 PM
Selbyl
Sep 22, 2015 10:41 PM
jaesa
Sep 7, 2015 01:50 PM
