Xfire sometimes won't start
Old Apr 11, 2010 | 02:21 PM
whtxfire05's Avatar
Default Xfire sometimes won't start
Recently my xfire has developed a problem of not starting (won't turnover at all, lights radio etc all work). This has occurred so far when car has been sitting in garage for couple days. I leave it alone for couple more days and try again and presto it starts fine, and will continue to start 20 to 30 times before it happens again. It has done this with both old battery & new battery (same cca as oem). Any help with diagnosis would be greatly appreciated. Thanks.
Old Apr 11, 2010 | 02:41 PM
GDC-SRT's Avatar
Default Re: Xfire sometimes won't start
Welcome to the forum.
Click the link below, should give all you need.
https://www.crossfireforum.org/forum...-no-start.html
Old Apr 11, 2010 | 09:57 PM
whtxfire05's Avatar
Thanks for responding to my question. I just checked out the "Mystery no start thread" and I will now take a look at my car's circuit board. If the solder joints are bad will this keep the car starter from turning over at all (like my car) or do the car's with this problem crank but don't fire? Thanks again for your help.
Old Apr 11, 2010 | 10:48 PM
tighed1's Avatar
No Crank - RCM
Crank no Fire - crank position sensor
Old Apr 12, 2010 | 08:46 AM
whtxfire05's Avatar
Thanks for your reply and your help. I'm glad I found this Crossfire forum. I had asked at my local Chrysler authorized Crossfire dealer about my car's problem and they didn't know what could be causing this because they said they have only worked on 1 Crossfire. I could just see the repair $$$ flowing out of my wallet. Thanks again.
Old Apr 21, 2010 | 08:52 PM
mrwhit08's Avatar
I am having the same problem as of 3 weeks ago. I thought it was the battery. Took it and had it tested and it read 600CCA of 700 so had it replaced. 2 weeks later it did the same thing. Just happened again tonight. My promblem is it will crank, with no fire... unless left alone for some random amount of time. Awesome.
Malcolm
****Note****
Had it jumped after the first no fire, and must have been coinsidence that it started because jumping tonight helped none, and besides the battery is new, alternator tested fine.
Old Apr 21, 2010 | 09:55 PM
mrwhit08's Avatar
Car started hopefully this time not due to coinsidence. Awesome. I can has love for you? Without my DSLR eyes, it looked as though I was having this exact problem @ 50000mi. Took 10 minutes, even completed the me so horny only to cause neighbors to turn porch lights on looking for some ruckus. Thanks Tighed I'll keep you guys posted on results in the week to come.
Malcolm
Bowling Green, KY
Old May 4, 2010 | 09:28 PM
mrwhit08's Avatar
Hummm... same issue again. Did seem weird yet again that :
No Crank - RCM
having bee said and the RCM trick fixed it, but I hadn't had the problem since the last post. Any other alternatives you guys' have come across other than the CPS needing, I assume, replacing or adjustment?
Old May 4, 2010 | 10:54 PM
mrwhit08's Avatar
Searched forums, replacing CPS tomorrow thanks autozone @ $54. Also, much thanks all on forum. It is very much appreciated.
Malcolm
Old May 6, 2010 | 12:28 AM
mrwhit08's Avatar
btw the "duralast" at autozone for $54 is a BOSCH like the others, but difference compared to say Oreillys for $89 is the 2yr vs lifetime warranty... just a heads up. I replaced mine tonight, it took about 10 minutes tops. Another heads up, have star sockets handy or a ... 1/4" driver - 1/4" deepwell along with a 6" extension. A small rachet helps in the tights space as well. Otherwise had no problem. I used an eyeglass screwdriver to pop clip up just enough to pull out the wiring/clip.
Malcolm
xfClifford
Mar 3, 2021 04:52 PM
jhansen
21
Feb 15, 2017 04:26 PM
oldvintagedude
Aug 14, 2015 06:20 AM
mthtulsa
Aug 3, 2015 06:14 PM
cx24724
Jul 12, 2015 11:57 AM
