Need Help with new crossfire!!!
Old May 5, 2010 | 11:46 AM
Motley05's Avatar
Default Need Help with new crossfire!!!
[FONT='Tahoma','sans-serif']I just recently got a 05 Chrysler crossfire coupe that I had a few questions about. First, I had a headlight go out and after I fixed it the Exterior Bulb Failure light stayed on. How do I clear it? Next, I had taken it to get an inspection done on it and the only thing they had found was that my front tires have a cupping pattern on the inside. I was told that my struts are worn; anyone else ever had this problem?[/font]
Old May 5, 2010 | 12:18 PM
Default Re: Need Help with new crossfire!!!
sounds like out of alinement not struts. jim
Old May 5, 2010 | 12:26 PM
Motley05's Avatar
The alinement feels like it is good, is there anyway my tires could have anything to do with it?
Old May 5, 2010 | 12:36 PM
sorry you can't feel the alinement,,, cupping could also be caused by balance.
Old May 5, 2010 | 12:40 PM
Motley05's Avatar
Ok, i will have it checked out and see, Thanks.
Anyone know how to clear the Exterior bulb failure light on the dash?
Old May 5, 2010 | 12:46 PM
maxcichon's Avatar
You will have to check ALL of the other lamps. Rear License plate bulbs seem to cause folks headaches. Does the indicator come on as soon as you start the car? Just marker lights (first click)?
Try to narrow it down?
Old May 5, 2010 | 12:48 PM
kingkub57's Avatar
Check all of your exterior lights ! park lamps, license plate bulbs, high and low beams, ETC, the light comes on when there is a break in the lighting system, if one or more are bad. About your tires well your going to have to get new ones any way and then at that time you can have the front end inspected, because I also think tires out of balance, and to get them re-balanced would be a waste of time.
Old May 5, 2010 | 12:51 PM
Motley05's Avatar
I will try to see if there is any others that may be out, it only comes on when i turn my headlights on.
Old May 5, 2010 | 12:54 PM
Stargazer's Avatar
Congratulations on your new ride! Were you able to snag a warranty with the purchase? You might use that to check out the light issue.
As for the cupping, if I were in your shoes (and I have been at one time or another), I would take the car to my mechanic of choice and have the alignment checked. I would also have him check the tires to see if they are still good for the street. If you need a new set, you can do some searches on-line here for Hanooks. They seem to give the best return for your $$ right now.
If you can stay on top of issues by having good maintenance, your car will last a long time. Let us know what the resolutions are - we share our learning experiences.
Old May 5, 2010 | 01:04 PM
Motley05's Avatar
Thanks to everyone for the help, this information will help me out.
rayth
41
Jul 31, 2019 04:02 PM
XfireAsh
Jun 22, 2015 11:19 AM
MJPowers
Jun 8, 2015 02:34 AM
WilliamT
Mar 21, 2010 03:27 PM
imported_mightyjlr
Aug 17, 2003 01:57 AM
