Bad Check Engine Code Question
Old May 5, 2010 | 01:14 PM
Darticus's Avatar
Default Bad Check Engine Code Question
This does not concern the crossfire but when we get a bad code reading why do we replace the sensor? Shouldn't we be fixing whatever is causing the sensor to get a bad reading and the sensor is good. I'm asking as most of you know the technical stuff inside and out and it just seems weird to change the sensor. Aren't we using sensors to test the engine? I take my JEEP Liberty to inspection but its says an oxygen sensor is reading poorly is the engine ok and the sensor is bad or is the engine bad and the sensor is telling us the engine is having a problem? Than why replace the sensor? Maybe someone can clear this up. Thanks Ron
Old May 5, 2010 | 02:49 PM
apkano's Avatar
Life is random...so am I.
Default Re: Bad Check Engine Code Question
To put it simply.....
Most tech's have a drawer full of "known good" sensors. It's much easier to switch out a sensor to see if that's the problem than to dig into a very complicated fuel or ignition system. Sensors are typically very easy to get to and switch out for a good one. Most mechanical parts will make some sort of noise, smell, or otherwise give some indication when they are failing. Sensors are just another electrical item...... when they go they just go.
Old May 5, 2010 | 03:00 PM
bmorgan's Avatar
If the code is telling you that you have a bad sensor, then the sensor itself is bad. It does not mean anything is wrong with the engine. Sensors are like any other electrical part. They will fail eventually.
jgreen
106
Sep 18, 2017 11:46 PM
spoiler
Sep 2, 2015 08:56 PM
axnguyen
Jul 21, 2015 11:41 AM
bdh
Jul 9, 2015 09:40 AM
Blackout317
Jul 7, 2015 08:38 PM
