HID wear on fog lights...
Old Jul 2, 2010 | 12:34 AM
mscard02's Avatar
Default HID wear on fog lights...
I was wondering if anyone could let me know from experience how the hid fog lights hold up due to them coming on every time you lock your car.. I know it is bad for hid's to turn them on and off constantly, and reduced the life of the bulb. Is there anyway to prevent the fogs kicking on when you lock the car? It just seems like it is really bad to drive with them on at night, pull in the driveway turn everything off and sure enough getting out you hit lock so they kick on again and off again about 10 seconds later
Old Jul 2, 2010 | 12:38 AM
Voyager's Avatar
Default Re: HID wear on fog lights....
hmmm I agree with you, I was thinking about putting hids in the fogs but now I think I will think about it a bit longer
Old Jul 2, 2010 | 12:41 AM
Infinite's Avatar
Its not that bad on the ballasts. Generally you should wait 5 seconds between cutting them on again. Running them as fogs isnt the issue. Make sure you get 35w kits as the 55w kits have been known to melt the plastic housings of small lights due to the extra heat, plus the higher wattage tends to wash out the color
Old Jul 2, 2010 | 12:46 AM
mscard02's Avatar
Yeah i made sure i bought the 35watts. So as long as I wait about 5 seconds or so it should not affect the life of the bulb and ballast?
Old Jul 2, 2010 | 12:52 AM
Infinite's Avatar
nope, not at all
Old Jul 2, 2010 | 01:15 AM
Voyager's Avatar
okay infinite, can I get some clarification. so you're saying we should turn them off for 5 seconds before pulling the key out so the fogs can come on? please forgive my ignorance
Old Jul 2, 2010 | 01:17 AM
Infinite's Avatar
There should be a 5 second wait time from turning them off to turning them back on. The biggest reason for this is the thermal shock of the arc can blow up the bulb.
The ballast can take whatever you throw at it, other than prolonged voltage fluctuations (old ballasts) as it causes the relays in the ballast to open and close randomly basically keeping the bulb in the light off phase so they never get up to temp
Old Jul 2, 2010 | 01:35 AM
Voyager's Avatar
cool, thanks for the follow up. I guess I'll pick up a pair of hids for the fogs. mine are shot because of water :/ I'll just have to make sure I wait five seconds before getting out of the car which shouldn’t be an issue
Old Jul 2, 2010 | 02:09 AM
Infinite's Avatar
no problem, information is what im here for
Old Jul 2, 2010 | 08:34 AM
maxcichon's Avatar
OK, Mr. Info:
If the OEM halogens are 55W, please explain how a 55W HID bulb is any different in heat dissipation.
This I gotta hear....
Old Jul 6, 2010 | 05:24 PM
Voyager's Avatar
well i'm sure as you saw from my post earlier I am no expert but I have been doing my homework lately because i'm thinking about putting hids in my fogs and headlights since my fogs are fried but everything I've heard is even though the halogen runs a bit hotter the hid is longer and will create more heat closer to the clear part of the housing and can create heat issues. but that’s just hear say. :/
Old Jul 7, 2010 | 12:12 AM
Infinite's Avatar
The projectors are glass, theres no way you're going to damage them.
xfireohio
Jul 20, 2020 12:03 AM
Mike OD
Sep 23, 2016 07:00 AM
Franc Rauscher
May 9, 2016 12:04 PM
AlbertFattal
Sep 24, 2015 05:03 AM
maxcichon
Sep 4, 2015 12:50 PM
